Spencer Mills Posted March 23, 2013 Report Posted March 23, 2013 This will be my first box build. I've got 2 SA 8 V.2s, so a I'll be building a ported box obviously. I want to have the subs facing up towards my back glass (hatchback with open trunk), with the slot port in between them. I'd like to have it tuned around 32hz. Each sub will be getting roughly 550w RMS from a PPI bk1800.1d My max dimensions are: Width: 22.5" Height: 14" Depth: 17" I've got a pretty good idea on what I need to do using the various calculators, but I would really appreciate if someone could do a quick sketchup just so I can get a visual in my head. Also, when I make the slot port down the middle, do I half the width of the 2 port walls going to each side of the box? Example: Slot port width is 1.5" on for the first section, then the back two sections (one towards each sub) are .75". Is that correct? Or should the entire length of the port be 1.5"? Thanks!
alehound Posted March 23, 2013 Report Posted March 23, 2013 Yes, cut port width in half when they split off. I still use pencil and paper, so I'm afraid I'm not much help with sketch up. Trust yourself, and put the saw to wood. You'll do just fine. Patiently waiting until 2016...the year in which I likely get to 300 posts... In which then, and only then, will I finally be able to get me some more decaf...
Spencer Mills Posted March 23, 2013 Author Report Posted March 23, 2013 Just spent the last couple hours playing around in sketchup, and I think I have a good design. I'll get the dimensions on the images and post them up eventually.
Spencer Mills Posted March 23, 2013 Author Report Posted March 23, 2013 If I did this correctly, this should be around 1.5^3 ft tuned to around 32hz
Joe X Posted March 24, 2013 Report Posted March 24, 2013 Don't think that's right..... can you post a screenshot of your calc output? also ony 22.5 wide?
john253a Posted March 24, 2013 Report Posted March 24, 2013 22x13x15d sub up port up 2x 3" aero ports 20" long (psp ports will work with centre port subs side)
CleanSierra Posted March 24, 2013 Report Posted March 24, 2013 .75 width on the back wall port width will NO DOUBT, sound choked to hell. Im with Jon but and say aero ports with those 8" subs. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted March 24, 2013 Report Posted March 24, 2013 Also, you have a small cabin, don't tune that low. Tune to 34-38 Hz and call it a day. You don't have to be tuned low to hit low, those subs WILL take care of that for you, they like the lows. Im not the one you want to try to troll. Just a fyi for you.
Spencer Mills Posted March 24, 2013 Author Report Posted March 24, 2013 So where would I put the aero ports?
Spencer Mills Posted March 25, 2013 Author Report Posted March 25, 2013 Also, the subs and port do not HAVE to face up, they can face any direction if that helps. But I would prefer that at least the subs face up. The port I don't really care about.
