(2) SA 8 V.2 Box Design Help
If you're using the Torres calculator set it to 2 round at 3in diameter, then adjust the length to get you're desired tuning frequency I suggest about 36-38Hz because the aero ports are more efficient than regular round ports. (The calculator can't give you exact tuning because you're using aero ports and your car itself is something you will need to work around). I would get an estimate of what you want, build it then play with the length of the port to get what you're looking for. Hope this helps
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
So here is a suggestion:
Enclosure Specifications:
Fb = 33 Hz
Vb = 1.2 ft^3
External Height = 15.75 in
External Width = 22.5 in
External Depth = 15 in
Port Width = 1 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 22 1/2 x 15
Left & Right Sides =
Side 1 = 13 1/2 x 13 1/2
Side 2 = 14 1/4 x 13 1/2
Front = 20 x 13 1/2
Back = 22 1/2 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 11 3/4 x 13 1/2
Extension = 16 3/4 x 13 1/2
Extension 2 = 8 3/4 x 13 1/2
Assembly guide (generic dimensions):
Important notes:
- The port needs 1 3/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
I have a 2dr blazer and I'm thinking about using these measures. My question is where should the port face? The back towards the glass, the roof or towards the rear seats?
'01 2DR GMC JimmyPioneer DEH-6300UBMB Quart 6.5'sSoundown Audio SA 8 V2'sMTX RT-202 GONEAudiopipe AP-1800.1D GONE
Bass-less :angry2:
Two 8s for a blazer seem like little firepower but if you do it, then subs up/port back like the above would be fine.
LIttle firepower? Eh, it gets the job done. Some people think I have bigger subs than I actually do. I might go with 12's before Scrapin' this year
Bass-less :angry2:
  • Who's Online   0 Members, 0 Anonymous, 1333 Guests (See full list)
