Yes there is more throw.
The Z v.4 series is our 1750 RMS rated line they feature a 3 diameter 8-layer flat aluminum coil wound on spiral cut black anodized aluminum former. They feature our new spider, surround, and cone platform. Production linear x-max is around ~35mm one-way by 70% BL with a total mechanical clearance of 62.5mm in the motor. The Z v.4 series features a large internal magnet shorting ring for reduced inductive distortion.
The X series is our 1250 RMS rated line -- they feature a 3" diameter CCAW round wire coil and our new frame, spider, surround, and cone platform. Linear x-max is around ~30mm one-way by 70% BL with a total mechanical clearance of 50mm in the motor.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Roger that. Appreciate the info man. I'll wait for Jacob to chime in and see if the z4 drop in would work without any problems.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
In your particular prototype the Z coil fits with no issue; I made a 10" prototype with a Z coil -- the production units are a bit tighter on the top plate ID so they would actually need a different coil to work without worrying about clearance (the Z coil would still fit but it would be tight). I'll have a slightly modified coil very similar to the Z coil for X series "SPL" re-cones down the line; originally I intended to them to interchange but the X gap worked better a bit tighter with production coils.
So once all the parts are in stock, yes, you could do that.
Edited by sundownz
  • Like (+1 Rep) 2
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Outstanding! Thanks for the info :good:
Also Jacob, do you have any idea when the recone's will be available to purchase? Either the z4's or the X SPL version.
Cool deal, thanks again!
  • 1 month later...
have you tried giving the x the full 3.5kw now ? if not, why ? :P
He has it at 2 ohm I believe
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
