Dirt bike stripped case bolts.. tap,heilcoil?
A "Time-Sert" is just a solid thread repair insert instead of a flexible coil type of insert such as a "heli-coil" - All I know is that if this bolt has a lot of pressure & vibration on it, odds are a heli-coil will fail over time, but if you must - Permanent loc-tite the heli-coil when inserting it and let it cure
Depending on the size you drill for the next size up and tap it and screw the keensert in and hit the pins down to set it and you now have a hardened thread that won't strip again. We used to use them in a machine shop i worked at when drills/taps would break off and need to be removed and would leave the hole oversized.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
well I took it apart today to figure out.. I'm an idiot haha
Guess out of the 3 long bolts I removed one is about 3mm longer.
Thank goodness saved me a headache
Duhhhhhh, I never even THOUGHT about that. I had that bike apart several times too. That should have been my first suggestion :(
http://www.ebay.com/itm/Suzuki-RM125-RM-125-right-side-case-clutch-cover-01-08-2001-2002-2003-2004-2005-/330897413025
eBay always have reasonably priced used cases if worst comes to worst. We all make mistakes like that ! Was putting together a top end last night on a 4 stroke and finally got the cams in time. I go to turn over the motor just with a ratchet, cams don't move. The cam chain had slipped off the crank in the bottom end and had to tear it down again.
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
