4 Obsidian 15s walled in a little Saturn
This is a build I had been planning but got caught up with work and school and it slowed me down...but now it is done, thanks to a ton of work by Premierdime on here.. 4 Obsidian 15s @ .5 on a DD m3 in a 2000 Saturn sl1. Polk Coax on a Powerbass 200.2 were already installed as was a 9886. I need to beef up my front stage soon. Stock alt with 2 Enersys Powersafe batts in the rear.
On to the pics
Subs
Trying to get the shell figured out
Double baffle flush mount
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
test fitting baffle
had to clamshell the back angle, was a pain in the ass
all joints glassed in, 2x4 bracing
Team Flex Issues
Low tuning > God
hell yah man tuned in for this!! :good:
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
masked off for expanding foam seal off
trim panels to hide foam and bracing
Team Flex Issues
Low tuning > God
Finished product
Team Flex Issues
Low tuning > God
I dont know why the pics are coming out different sizes.
Anyways the original plan was 12.5cu @34hz and about 15^2. We hit a ton of unforeseen bumps during construction, so specs changed. Port area ended up being 14^2, we lost volume and increased tuning, my best guess is roughly 11.5cu @38hz. I went to get it metered yesterday with zero tuning done and the best I could muster was 147.8 on music at 34hz, which was dissapointing to say the least. Across the board my numbers were low and this sounds like 50 all day on music. So we starting trouble shooting; I was hitting 8 or 9v on burps and wasnt charging much above 13v. When I hooked my volt meter up, I was actually dropping so low that it was shutting off. So I came home and continued trouble shooting. I was loosing 2v down my power wire; loose connection was the culprit. Now Im back to charging at 14v. and can basically stay above 12v unless Im 100% full tilt. (Stock Alt FTL)...I plan to add a second alt where my AC compressor is being it doesnt work. I'll go re-meter whenever, Im sure it will do 50s as is. Will also get some videos up.
Team Flex Issues
Low tuning > God
Team Flex Issues
Low tuning > God
Looks good hope to hear it at a show one day but what happen to your team most of them sold off the stuff?
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
