Just like the title says, where is the best place to mount Dei dual shock sensor?? I can only reach my driver side under the dash or around the steering column??? Maybe the center behind the console where you guys mount them?? I am almost done. Just have to mount that then put cover on and that is it.
Yes.. I can rest easy tonight. Alarm is on and working perfectly. Protected. I love it. Very sensitive and the 2 way remote is off the chain. It has so man features I still will be learning weeks from now. For $150 you can't beat this one. Especially if you drive a newer vehicle than I have. One with power locks and automatic tranny. That remote start feature would be killer.
remote start alone is wonderful.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
One of your questions was where to mount the shock sensor...
I usually do ignition harness... a big harness of wires is usually the best. just ziptie it to them.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
  • 3 weeks later...
My car did not have power locks either, but i bought some 2 wire DEI actuators and wired them straight to the alarm. as long as you have door lock rods you should be able to do it. parts might cost you $50 for a 2 door car with a DEI door lock relay.
DC.jpgDC POWER
For real let me go and check that out. Yeah I have the door lock rods. They are horizontal, but that shouldn't matter. Let me go and find these.
If you dont mind a little wiring you can just buy 2 standard bosh relays and skip the Dei module .
http://cgi.ebay.com/DEI-524T-Power-Door-Lo...1QQcmdZViewItem
those are the ones i have and they have been going strong for 2 years not a single problem .
its not as hard as it looks. you have 2 wires off your alarm green and blue one is lock and one is unlock. They reverse polarity to switch from lock to unlock
DC.jpgDC POWER
