2 Questions about my HID Lights
1) on cold starts, my right bulb doesn't always fire up. I have to flip the key a few times...easy to do but annoying. Why is this?
2) I pull headlight out codes for both headlights. How do I fix this issue and trick the car to thinking its fine. Im using a relay and my factory plug has nothing connected to it, hence why it pulls codes. Is there a cap/resistor i can put in it to trick the system?
Car is a 2008 Saab 93. The HIDs are in the projector head lamps. I'm using the canbus ballast that is supposed to eliminate the codes but that is a lie...
I dont have any flickering issues either.
help me please!!
Have you tried swapping relays, ballasts, and bulbs between the sides (to try to find what exactly the issue is)?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
For the headlight out codes you need a code deletion harness. You can find em on just about any hid website. I recomend www.ddmtuning.com
2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq.
for #1 I have the same problem and mine is caused by voltage. Try to kick on your lights with the vehicle off. If they both start then turn on your engine and wait a few seconds. Try to turn on the lights now that the engine is on. If you only have one that works and the other one doesnt then you have the EXACT issue I do with your voltage fucking with the ballast wanting to fire. I have my setup 100% correct with independent relays, ballasts, bulbs, etc. and it gives me that problem. Even bypassing the switch still does it to me. I have a thread on trying to figure out how I can wire a resistor in line with the ballast to lower the voltage just enough to make it turn on when my voltage is too high (when my truck is very cold I charge at around 14.8-15.2v on average).
As for your headlight out warning its simply a little resistor that goes in line with the stock harness before it plugs into your relay harness (if you use one, you really should to prevent melting the stock wiring harness) and the resistance resembles the resistance levels that a halogen bulb possesses when it is lit.
For #1 even kicking just the lights on before the engine, the issue is still there, its just luck if it works on the first try but that is rare
and would an error canceler harness work to fix the codes?
Yes its merely a resistor inside a pretty looking and easy to connect unit. Super cheap and in fact if you trust your ability to splice and run a resistor in series with the wire you can go to radioshack and get a resistor that is the right resistance and wire one up yourself but be warned they can get pretty hot so put it somewhere that it cannot burn your paint or anything like that.
As for kicking it, that isnt doing shit for you. Just try like I said. I had the issue where after a few months of troubleshooting it, hard wiring the relays to their own switch, putting the ballast directly to the battery instead of through a harness it still happened when the voltage was too high. All my other lights were fine but the one 50w ballast I had would fuck up every time. I sent it in for service and it was "tested" and came back to me after I paid shipping for a total waste of my and their time only to have it still fuck up. Another thing you can do as long as you don't hold it there forever is if you have electronic windows, hold all 4 window switches in the up position and once you hold it there immediately switch over the headlights so they kick on. If they fire then your issue is voltage because when your windows are already up and you push the up button it makes a huge load on your electrical system causing the voltage to drop and be in the area where the ballast wants to fire at.
Personally I think its a problem with the ballast but the company I bought mine from kept denying it... :jon::jon:
what ohm resistors will i need?
right now my factory harness is completely disconnected i believe so of course the car thinks the lights are out lol, but i have nothing that needs to go to it you know?
So how do you have the lights working if you disconnected it from the harness? Are you using a dedicated switch and relays for the ballasts? Almost all relay kits have it where you plug the stock wiring in one part of the relay kit and this connection is what energizes the relay to make the power flow through from the battery to the ballast connections offered from the relay kit itself.
As for your resistance I am not too sure what you need for resistance. Different cars have different ranges that they check for the bulb out warnings.
  • Who's Online   1 Member, 0 Anonymous, 587 Guests (See full list)
