Cboeger Posted April 4, 2013 Report Posted April 4, 2013 if bass boosted songs gives clipping/distortion to your subs, then does that mean any song bass boosted or not could ruin your subs even if your gain and stuff is set correctly?
Guest Posted April 4, 2013 Report Posted April 4, 2013 if bass boost gives clipping/distortion to your subs, then does that mean any song bass boost or not could ruin your subs even if your gain and stuff is set correctly? the song clips, you're likely going to clip the amps even if gains are set correctly. a little red in audacity is fine. the whole song is red and you have an issue.
Omega5002 Posted April 4, 2013 Report Posted April 4, 2013 As long as the song isn't horribly clipped, and not bass boosted to all hell, you should be ok. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Omega5002 Posted April 4, 2013 Report Posted April 4, 2013 I'd examine the song in audacity, if a few red appears, you'll be fine, now if it's all red, stay the hell away like Kranny said. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Skater229 Posted April 4, 2013 Report Posted April 4, 2013 but can't you use audacity to clean it up also? and get it back in the butter zone? 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
Noel989 Posted April 4, 2013 Report Posted April 4, 2013 nope you cant it can be reduce but the way I see is just like playing your stereo a few clicks down than normal Build Log - http://www.stevemead...-cruiser-el-pt/
Guest Posted April 4, 2013 Report Posted April 4, 2013 but can't you use audacity to clean it up also? and get it back in the butter zone? you cant unclip a song...well, you can, but you have to go and reshape every sine wave which will take like weeks. if you deamplify a clipped song, you're just making the clipping, and overall song, quieter. its still clipping.
DubNDodge Posted April 4, 2013 Report Posted April 4, 2013 but can't you use audacity to clean it up also? and get it back in the butter zone? Once a song is dirty, it stays dirty. Unless you go back and completely reconfigure the song. Another thing to look for if you have a volt meter and you know your average volt drop. On a clipped song your voltage will drop a bit more than usual. That will give you a sign that a song may be clipped edit: ninja'd '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Skater229 Posted April 4, 2013 Report Posted April 4, 2013 you cant unclip a song...well, you can, but you have to go and reshape every sine wave which will take like weeks. if you deamplify a clipped song, you're just making the clipping, and overall song, quieter. its still clipping. Gottcha... Thx... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
