regular box
yea man boxes are harder than you think...just do the regular one first...then after a couple try the t-line...im on my 4th box and i still go a little off track... <_<
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
If you insist on liquid nails over tite bond then alright do it. Tight bond works better. Liquid nails is for stuff like sub flooring and heavy duty use that requires a moisture proof glue. A MDF box does not. Also if you use silicone, which you wont have to if you use tite bond, - LET THE STUFF DRY COMPLETELY !!!! Silicone has chemicals in it that gives off fumes that can cause harm to sub woofers, and I would imagine that liquid nails does too. DO NOT put your woofer into your box until the silicone and or liquid nails is completely dry !!!!!
With tite bond all of this will be a complete non-issue :)
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
I just thought everyone used Liquid Nails Extra Strength.
nope
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
like everyone else said....
Liquid nails sucks!
use TiteBond II unless you're a baller. Then use TiteBond III ;)
If i dont have access to an air nailer with 2" nails, i use 2" drywall screws. You MUST predrill the holes if you use screws.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
or you can do like man and use silicone ........ let it dry and then bead over it with some liquid nail.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
