LordArcane Posted April 7, 2013 Report Posted April 7, 2013 Well, fuck, what if your HU is twisted pair, and your amps input is coax? Guess ill keep the twisteds in and order some coax, just in case. yeah, that i have no clue what you would do i know tony says in his video but, like a lot in his videos it kinda went over my head i think. i got lucky and all my stuff so fair is all twisted
LordArcane Posted April 7, 2013 Report Posted April 7, 2013 DAmoreEngineering 1 month ago If the head unit has SE outputs and the amplifier has SE inputs = coax cable If the head unit has SE outputs and the amplifier has Diff inputs = twisted pair If the head unit has Diff outputs and the amplifier has Diff inputs = twister pair If the head unit has Diff outputs and the amplifier has SE inputs = bad no matter what as you will shorting out half of the head unit's outputs. In this case you would need an amplifier with Diff inputs or a converter to convert the head unit's outputs to SE Edit: also was wrong about the pioneer deh 80prs it is coax not twisted. just went to car and double checked
OrionStang Posted April 7, 2013 Author Report Posted April 7, 2013 Good find. Now as long as AQ amps don't have coax inputs (pretty sure they don't) Im good to go. SMD Super Seller My Feedback Thread
HunterJohnson Posted April 7, 2013 Report Posted April 7, 2013 How do you check with dmm? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LordArcane Posted April 7, 2013 Report Posted April 7, 2013 put your dmm on continuity setting or ohm if it doesn't have the continuity setting. then ground the - lead and touch the outter ring of the rca with the + lead if it has continuity its coax if not its twisted.video tells it as well i'll repost
HunterJohnson Posted April 7, 2013 Report Posted April 7, 2013 put your dmm on continuity setting or ohm if it doesn't have the continuity setting. then ground the - lead and touch the outter ring of the rca with the + lead if it has continuity its coax if not its twisted. video tells it as well i'll repost http://www.youtube.com/watch?v=QOagVDZLQnA That's easy. Ill buy an RCA and solder dmm leads Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LordArcane Posted April 7, 2013 Report Posted April 7, 2013 just as easy to do it normal way only need the + lead to test with the - will be grounded to battery, then as above just touch/poke whatever you prefer lol the outer ring of the rca output of the h/u,amp, etc...
HunterJohnson Posted April 7, 2013 Report Posted April 7, 2013 just as easy to do it normal way only need the + lead to test with the - will be grounded to battery, then as above just touch/poke whatever you prefer lol the outer ring of the rca output of the h/u,amp, etc... Yeah that's true Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
CortezDTV Posted April 8, 2013 Report Posted April 8, 2013 What is an alpine CDA 9887? And what if I go to a jbl ms8?? Edit coax the whole way SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
AMI CUSTOMS Posted April 8, 2013 Report Posted April 8, 2013 AQ have differential inputs, I tested no connection at RCA with DMM. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
