n8s full size makes noise?
it is. My truck came equipped iwth buckets in the front with the captains chair style arm rests. made it real easy to put the amps int eh center like that since I just had to remove the console and utilize some of the factory mounts.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Still dont know how you did it lol
If it were me I would be having trouble fitting a single 12 and amp in there ;)
Nice ...
Do you have that second battery enclosure on the driver's side under the hood?
Mine has that 60/40 shitty seats ... I have a 96 parts truck with those similar buckets that needs recovering (one of my many next on the list projects) saved for later. Does the center console "bracket" section move with the driver's seat ??
i actually have no pictures of the truck in stock trim I dont think but the center console was a floor mount unit that was stationary. Its pretty much bolted down in the center with four bolts.
In this pic the two rear cross sections are where its bolted down to the floor.
heres what it looks like with nothing there. The uncarpeted spots are where the brackets were bolted in place.
not the best but you get the idea. Its pretty solid. When the seats are in the amps are pretty snug so its really solid that way. And when the rest of the console gets finished it will be even more solid.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Wanna know what's a funny coincidence, your name has 2013, and you finally get your truck playing in 2013 lol.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
lol. I expected 2015 to be honest. Ive had alot of time off from work and an ammo shortage makes this the logical thing to do. If steve gets that sunflash out I can knock out my doors soon.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
that stuff's going to be pretty expensive though right? I mean it's definitiely convenient to have something "sketchy" dry in seconds so you don't have to worry about it
I never realized how dark your windows were? What percentage are they ? 5%
Also you're running the orion 2500's arent you? What do you get outta them at full power?
Team MaxRetribution
Si Vis Pacem Parabellum
I want the sunflash because it wont warp from mixing it too hot. Something I tend to do often.
Bobby its 5 percent. I need to take it back in and get a brow done on top.
yes those are orion 2500ds. I see .7 at each amp so I'm probably getting 3k out of each right now if i keep my voltage up. Im working with mechman on getting an avbm2 shortly so that will be a non issue.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1429 Guests (See full list)
