Whats This White Thingy?
audiofanaticz
those are resistors
not caps
those are resistors
not caps
^^^Beat me to it.
"Ballast" resistors...(?)
Or just regular old ones.(?)
But resistors for sure....
Maybe double check ur ohm load at amp w/ only one there?
Might end up throwin some wierd impedence and do some harm to subs/amp...?
He^^ Would know better than I tho. :blush:
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
regular resiters... resisters of that magnitude or more better for wattage handling, but only from like 5watt- 30 watt, unlike the 1/4 watt resitors you see on the rest of the amp board.
You can buy those resistors to make your own home made crossovers, I have lots and lots of them
In a crossover you use them to attenuate sound, to make a tweeter or mid louder or quietr by manipulating its resistance
Higher impedance quieter, lower resistance, louder.... Very simple terms
The amp is in my spare tire well with a 3" piece of foam on the bottom and top of it the box is kinda resting on top of the foam, trying to stop the amp from moving. but my trunk floor is just moving and i cant stop it no matter what.
So Im sure it rattled loose lol
the ones in the rf amp read
RCD K6-481
5W 3K J
I got a kicker kx650.4 chillig here with
5WO.1(Ohm symbol)J
so they may be pretty close in size?
I was gonna take the good one out the rf and try to see what it puts out for numbers on my dmm, and then do the same with the kicker ones.
Whats could happen if you put larger or smaller resistors in?
Theres all kinds of things i want to do to this amp. bigger fets, power supply etc...
5W 3K J
^^^^^ 5 watt, 3000ohms
5WO.1(Ohm symbol)J
^^^^ 5 watt 0.1ohm
on such fine scales, you can use resistors from 0.01ohm to 1m ohm, its all in the circuit
  • Who's Online   1 Member, 0 Anonymous, 1849 Guests (See full list)
