Amplifier Questions. I need help.
BL4CK M4GIC
Ok if you want to get louder there are things you can do to help that, what enclosure are you running, whats your electrical like? If your amp is getting really hot your probably clipping the hell out of it. You can not hear clipping at all, it's not the same as distortion.
Pick up a DD-1 to insure your not clipping and you remain distortion free!! (if you do it right lol)
Edit: straight ninja'd
If your amp is getting hotter than it should you may not have proper voltage. In general, kenwood amps are pretty current hungry. You ill want to check your voltage at the amp. Also, your gain setting is not a volume knob. It is to match the input from your head unit. The higher the voltage your amp sees through the signal cables the lower you need to set your gains.
What is your electrical like? I would imagine you are starving your amp for current and sending distortion to your sub.
What is your budget for your amp?
Well I dont wanna go broke from an amp. Something that can power it and not overpower my wallet lol. 250-300 most likely. right now im running 4 gauge power & ground and it gets the correct voltage. also have a power cap. I tune my amps at 3/4 volume on my deck so its not distorted that high.
Is your electrical stable enough to support a cap? If it isn't then your cap isn't helping. What alt do you have and is your big 3 done?
Edit: You may not need a new amp, sounds like there be a bit you can do to realize the potential of what you have. Lets do that first and go from there.
Edit: what do you have subsonic and LP crossover set to?
Are you SURE that you are wired to 2 ohms? How do you know this?
I know because its a dual 4 ohm sub. I also hooked a multimeter to the pos. and neg. and i got around 2 ohms. It only has LP and its set to 15hz. can be 0, 15 or 25
HEAD UNIT - JVC KD-G430SPEAKERS - Pioneer 3 ways in front & backAMP(S) - Kenwood 1000wSUB(S) - JL audio 12w6v2CAPACITOR - Performance Teknique 2 farad (digital)SUB ENCLOSURE - Custom built to spec slot portedBATTERY - Duralast (for now)ALTERNATOR - ?WIRES - Pro auto sound 4 Gauge power & ground wire
Big 3? lol sorry im a partial noob. Ive heard of that but have noo clue what it is. ive got 4 gauge to starter, fuse box, amp and also 4 gauge battery ground to chassis.
What size and brand are your cap? and how far away is it from your amp?
Performance Teknique and 2 Farad. Literally right next to each other lol. like 8 inches
Your LP filter is set to 15hz??
Sounds like you mean subsonic which is basically like a HP filter. What enclosure are you running? You need to raise your SS filter setting it sounds like.
Im running a slot ported box custom built & tuned to jl spec. Electrical is good. nothing wrong. It probly is a little but not much. I might soon hahaha!
Op look up the big 3 tutorial on here. A lot of people leave out the return path to the alt. oh and is this the only aftermarket accessory drawing on your electrical system?
  • Who's Online   1 Member, 0 Anonymous, 832 Guests (See full list)
