XS Power
Will an S3400 fit under the hood of a 2013 kia forte 2.0?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
... measure it
Edited by OrzechNJ
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
As i understand it kia/hyundai are similar.. you have the 2.0.. i just put a 3400 in my car today. lemme look up the standard BCI for your bat and ill get back in a min..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Ok could you give a picture? I cannot find any god damn info regarding BCI size.. 550cca which is the same as my battery.
its prolly similar. in that case you can buy the xs power battery hold down kit for like 179 or something crazy..
take the battery out 4 or 5 bolts hold down the factory battery tray. remove. replace with the xs one, a d3400 fits just fine.
The d3400 ALMOST fits perfect without modification, however the lips that surround the battery tray arent large enough to hold the battery. it sits on top of the them if that makes sense..
you could buy a universal battery tray from autozone or where ever and replace the OEM one just like above and use a battery hold down kit to hold it place.. all in all costing like $25..
what I did.. remove battery drilled holes in OEM hold down tray and used a hold down kit.. like i said it doesnt fit perfect like the edges around the tray dont hold in the bat but other wise its fine. i could get a universal tray to fix that like above, but i think its fine how it is..
IMAG0648_zpsf48d2ef1.jpg?t=1366051192
Setup:
Xs D3400/ Xs XP3000
Dude: easiest way to see what will fit and what won't is to go out there yourself with a tape measure lol
I don't have any of my tools and just wanted to see if anyone knew if it fit. I have an S3400, D2700, and XP950, I was just wondering if I could fit the 3400 in the stock location, but I'll just do a little modifying to get what I want.
Edited by TylerParrish
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 1976 Guests (See full list)
