Fennygolf Posted April 19, 2013 Report Share Posted April 19, 2013 hey guys finally got my mids and highs amp hooked up and i started to get engien noise so i thought hey just ground my RCAs on the HU and it will fix the problem but i tried that ive check all grounds and all different kinds of things and ill be damned if the engine noise wont go the hell away i could really use some help any suggestions please comment Link to comment Share on other sites More sharing options...
revoracing247 Posted April 19, 2013 Report Share Posted April 19, 2013 any way to try a different HU? then you could at least rule that out. I think you have a bit of truck stuck in your mud bro ~Ford Ranger, ext cabKenwood DDX4701/0ga stinger wiring for big 31/0ga ofc flextech wiring 3 kinetik 800's AQ2200 @1ohm Sundown Audio X15 in a 27Hz tuned ported box LE BUILD LOG!!! Link to comment Share on other sites More sharing options...
Fennygolf Posted April 19, 2013 Author Report Share Posted April 19, 2013 any way to try a different HU? then you could at least rule that out. i have a spare hu but it only has a sub output on it but i tihnk i could probably find one Link to comment Share on other sites More sharing options...
newls1 Posted April 19, 2013 Report Share Posted April 19, 2013 welcome to my world... Tips i have gotten which helped but didnt fix the issue is: Ground the HU to where your amps ground at, obviosly use quality rca's to see if that helps, run a ground wire around all rca connectors on back of HU and ground that "strap" to the HU itself. Ground chassis of HU to where amps ground at...... I love my staffie So anti FACEBOOK it isn't even funny Link to comment Share on other sites More sharing options...
Fennygolf Posted April 19, 2013 Author Report Share Posted April 19, 2013 welcome to my world... Tips i have gotten which helped but didnt fix the issue is: Ground the HU to where your amps ground at, obviosly use quality rca's to see if that helps, run a ground wire around all rca connectors on back of HU and ground that "strap" to the HU itself. Ground chassis of HU to where amps ground at...... i did that also i even REDID my grounds that i have to my frame took them off ground them down some more to see if that would change anything but it didnt Link to comment Share on other sites More sharing options...
newls1 Posted April 19, 2013 Report Share Posted April 19, 2013 yuppers, i hear ya... been fighting this issue for a long time... Join my club and lets get the new alpine 149bt HU... should fix us up fer good Ill be nice and let you buy it first and let you tell me if it fixed your problem, then ill buy it I love my staffie So anti FACEBOOK it isn't even funny Link to comment Share on other sites More sharing options...
Fennygolf Posted April 22, 2013 Author Report Share Posted April 22, 2013 yuppers, i hear ya... been fighting this issue for a long time... Join my club and lets get the new alpine 149bt HU... should fix us up fer good Ill be nice and let you buy it first and let you tell me if it fixed your problem, then ill buy it YOUR SOOOO FUNNNY!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
