KiKaZz74 Posted April 24, 2013 Report Share Posted April 24, 2013 So my dad won a new black and decker rp250 variable speed plunge router in a raffle. Since he won't use it he gave it to me. Just looking for some tips, reviews, accessories, and ideas. Like what are some bits to grab? Roundover, a fancy one for trim for my moms stuff probably. How about a bearing one for like paterns and plunging and trimming holes? Also wtf is a spiral up/down cut bit called. Never see them in stores so I'm clueless. What are some other ones? Its got a vacuum attachment so I can do upcut. But here it is. Clear base, chipgaurd, straight line guide. Any help is appreciated guys. Thank you. Cody C. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
KiKaZz74 Posted April 24, 2013 Author Report Share Posted April 24, 2013 Also what is a good jasper jig to go up to like 18"? Not looking to spend much on that or I'd go a toolmaker one. Like $30 $40 for one. And what brand bits should I look at? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
tacomaguy1 Posted April 24, 2013 Report Share Posted April 24, 2013 Jasper is the brand...search Jasper circle jig Flush trim, roundover and spiral upcut or downcut are the 3 I use for pretty much everything Team Flex Issues Link to comment Share on other sites More sharing options...
KiKaZz74 Posted April 24, 2013 Author Report Share Posted April 24, 2013 Oh. Didnt realize that. Any good brands to recommend for jig or bits? 1/2" roundover probably, what size up or downcut? And is that what the bit is actually called? And the flush trim is the bearing one? Sorry I'm new to routers. And btw. Is this a good router? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
tacomaguy1 Posted April 24, 2013 Report Share Posted April 24, 2013 Yeah flush trim has a bearing that rides on whatever your trying to trim the piece to. Team Flex Issues Link to comment Share on other sites More sharing options...
KiKaZz74 Posted April 24, 2013 Author Report Share Posted April 24, 2013 Picked up some bits today and a blade for my saws. Got 3 bosch bits- 1/2" roundover, 1/4"x1" upcut, & a 1/2"x1" flush trim bit. Also picked up a 3pack of blades for my saws. 2 40tooth blades and a 60tooth. I think this will be good for now. Now to find a circle jig and letter or tracing jig My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
HunterJohnson Posted April 24, 2013 Report Share Posted April 24, 2013 Is that a 1/2" or 1/4 shank Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
KiKaZz74 Posted April 25, 2013 Author Report Share Posted April 25, 2013 1/4" I believe. But I can change the collet if needed just don't have a bigger one to put on atm. Also got a free lincoln stick welder with cart and rods from friend. I'm cleaning cart up now to paint it. Its all rusty. Just need to get a 240v line run now. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
HunterJohnson Posted April 25, 2013 Report Share Posted April 25, 2013 i prefer white side router bits. they have a few kits that are awesome, just get em and they'll last forever Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
KiKaZz74 Posted April 25, 2013 Author Report Share Posted April 25, 2013 I know but my mom was having a cow already about these. And I dont want to have to order them in. But any recommendations for a circle jig? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
