yourstruly232 Posted April 26, 2013 Report Posted April 26, 2013 I have a 2000 Corolla with veryy bad paint chipping on my hood and i wanna plasti dip it but idk how long i plan on keeping it there, has anyone ever done this? how durable is it?
Freshman6969 Posted April 26, 2013 Report Posted April 26, 2013 Pretty durable, make sure you do atleast 5+ coats more coats easier to peel off Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
ThreehundredC Posted April 26, 2013 Report Posted April 26, 2013 get the right distance so it doesnt make a rough surface it should be heavy coats so it can slide into an even coat but painting big parts like that i would use the spray gun vs a can,altho it will work too
ncochran Posted April 26, 2013 Report Posted April 26, 2013 I have plastidipped my wheels, emblems, gas cap door, grill, shift knob and a pretty fair portion of the trim on my dash. I also plastidipped my wife's Ipad with a carbon fiber pattern (4 times cause I kept getting the pattern crooked and she is ocd about shit like that lol). I have found that if you have chips before you dip, you will be able to see the marks after you dip as well. I suppose it is possible to put enough layers on that it smooths over the chip, but that seems like a lot of plastidip to do that lol. Depending on how much you care about your paint, you might want to consider sanding, or even some light filler/sanding to smooth things out before dipping. Some of the coating on my wheels was flaking off.. I dipped the first wheel and could see the lines/marks where the chips were at. I sanded the chipped areas on the other 3 wheels and they are flawless. Dip seems fairly durable and the best part about it is that you can touch it up or respray in most cases. And if you can't then you just peel it off and start over with nothing lost but a little dip and some time. 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
Crandis16 Posted April 27, 2013 Report Posted April 27, 2013 My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
yourstruly232 Posted April 28, 2013 Author Report Posted April 28, 2013 Woww that was just with plasti dip? damn you should live by me and do that to my car lol
naughtyca Posted April 29, 2013 Report Posted April 29, 2013 im thinking of doing plasti dip as car bra, can this be waxed? can clearcoat be applied on top of plasti dip to make it shiny?
Torres Posted April 29, 2013 Report Posted April 29, 2013 not by normal stuff. there's videos of how it'll react when you try to peel it off if you use normal clear coat. they do have different finishes tho. glossifier being one of them. i want to do a pearlizer on my truck and/or metalizer on my stock wheels (until i get new ones)
naughtyca Posted April 29, 2013 Report Posted April 29, 2013 what happens when you accidentally wax it, does it turn white? it just feels sticky and seems like dust will stick to it.
ncochran Posted April 29, 2013 Report Posted April 29, 2013 not by normal stuff. there's videos of how it'll react when you try to peel it off if you use normal clear coat. they do have different finishes tho. glossifier being one of them. i want to do a pearlizer on my truck and/or metalizer on my stock wheels (until i get new ones) I thought pearlizer would be cool, but it lightens your base color so much that it sorta sucks lol. I tried going light with it, but then i couldn't see the effect. Even with just 1 medium coat, it takes black and turns it to about the color of the gunmetal dip. And it made my gunmetal turn almost white. I think pearlizer on a white base coat would look nice, but for the other colors I have tried I don't like it. Metalizer is badass though. If I didn't like the looke of matte black on my wheels so much right now I would totally put some metal in there. So far I have used black/gunmetal/metalizer/pearlizer and glossifier, as well as their carbon fiber kit. I am probably going to dip my whole car black within the next month or so I think. 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
