Stephen Dunnington Posted April 26, 2013 Report Share Posted April 26, 2013 I'm about to place a order on 2 Sundown 12's that will be pushing 1200w RMS and I'm trying to figure out what would be the correct type of amp for these(wattage wise). I'm trying to keep it a little cheap here Link to comment Share on other sites More sharing options...
Omega5002 Posted April 26, 2013 Report Share Posted April 26, 2013 Budget? 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
PsychoSoundz Posted April 26, 2013 Report Share Posted April 26, 2013 any 2k should be fine mabe the aq(sq) 2200 to give u an example. ive used the kicker 2500 and a rf t2500... the t2500 is way more efficient and seemed like it had alot more usable power Link to comment Share on other sites More sharing options...
Toofast4u Posted April 26, 2013 Report Share Posted April 26, 2013 Any idea how big the box will be for em'? Link to comment Share on other sites More sharing options...
audiofanaticz Posted April 26, 2013 Report Share Posted April 26, 2013 1500-3000 watts of clean power should do the job nicely! Link to comment Share on other sites More sharing options...
PsychoSoundz Posted April 26, 2013 Report Share Posted April 26, 2013 1500-3000 watts of clean power should do the job nicely! C L E A N. being the main word to look at. sa's can take up to 3k or so .but it has to be clean or those bad boys will go up in smoke. ive seen 3 of them go Link to comment Share on other sites More sharing options...
Stephen Dunnington Posted April 26, 2013 Author Report Share Posted April 26, 2013 I'm using my Kicker DCVR box(http://www.sonicelectronix.com/item_21895_Kicker-DCVR122-10DCVR122.html) It's h-"16 w-32" d-14" Link to comment Share on other sites More sharing options...
john253a Posted April 26, 2013 Report Share Posted April 26, 2013 Anything over 1k will do the job But closer to 1500 is better Your coil config will also play a bit 2x d4 is 1ohm stable so you need a 1ohm stable amp 2x d2 is 2 or 0.5 ohm Any quality 1200+ amp will alway make more If you run 1ohm final The aq1200 or sax1200 is what idd use if you have stock elect If you have h/o or some extra batt Aq2200 Sax2000 T1500 Link to comment Share on other sites More sharing options...
Stephen Dunnington Posted April 26, 2013 Author Report Share Posted April 26, 2013 Budget? $300-350 Link to comment Share on other sites More sharing options...
john253a Posted April 26, 2013 Report Share Posted April 26, 2013 That box temp is ok But build or have someone build u a real box You'll get more output out of the right box the more power Link to comment Share on other sites More sharing options...
