So i took off my door panels and theres factory spray on deadener on it it looks like can i just put my second skin over that and will it stick ir should i just put it around it? Thanks guys
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
I have had both spray over deadener and deadener over spray. They work fine. I had really good results from the spray over the Deadener. I used Second Skin Spectrum over there damplifier and it was amazing.
Ok thank you guys for the reply!
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
Damplifier and Damplifier Pro will stick to most surfaces, but when it comes to an already applied coating it depends entirely on the coating's formula. Since there's really no way to know the coating's formula(at least no easy way) I recommend putting a small piece of something adhesive(some kind of tape would work best) on the already applied stuff and checking in a day to see if the adhesives seem weakened. If yes, then definitely avoid putting Damplifier or Damplifier Pro on it, but if the tape is still stuck as well as it was when you first applied it, Damplifier and Damplifier Pro will stick fine!
