need help to chose DD amps
gally
oh my god...im not running the both amps on 1ohm....i will be running both amps either on 2 or 4 ohms....
so if i would be running both emps on 2 ohms, each of the amp will be seeing 1 ohm
if i run them both in 4ohms, each amp will be seeing 2 ohm....im not running my amps both on either 1 or 0,.5
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
i will be getting either the m3a or another m1b tomorrow...
dont know which one yet
Seems like everyone recommended the m1. I would also recommended the ?1. I had a choice of either getting a did m4a or 2 nendo bc3500's.... I went with the nendo thinking that imp rise will be split between 2 amps instead of 1 which in theory would result in more power
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Again here's your problem. Your subs are D2 which means hooked up either together in parallel or series on one amp you can do 1 or 4 ohm (this is also what you'd have options for strapping both amps but each amp will be doing half that therefore you can't go 1 ohm strapped). If you run your subs separately you can go 2 ohm. You cant go .5 ohm on those DD m amps because the amps aren't stable for that and will likely damage itself.
I've already mentioned earlier what i'd do in your situation.
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
if he has two he can run them at .5 or 2 or higher.
if he runs one each he can run them at 1 or 4
even if he did those dd amps are retarded and would be able to take .5 all day.
I still say 1 m1b per woofer at one ohm > all other suggestions.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
my opinion is to get the M1s. strap them use the bass knob that comes with them and wire to 2 ohms.
honestly DD amps love to be wired low. .5ohm a piece all day on them will not hurt them. i do it all the time.
a lot of people with no experience with DD amps are chiming in and giving you false information.
screw the manual, no you wont fry it if wired low. i run .5 ohm daily, my buddy runs .375 ohm daily. my other buddy runs 1 ohm daily and .25 ohms for burps. i will be running .25 ohm for burps and see how they like it daily. if you have a big batt or 2 in the back you will be fine. watch your voltage and be smart though. dont be running them that low at 11 or 10 volts and lower. be smart and they will produce some serious power
the only issue with wiring the m1s low is their surface area and footprint of amp. at least on m1c they are so small they cant effectively cool at lower impedence in the summer so id recommend a fan. but the m2bs have enough surface area cooling to run lower. especially the m3. honestly you cant go wrong with either.
but if the m1 is cheaper go with that. you wont be disappointed.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
ive run the m1b at 0,5ohm and belive me...the car died first...the amp was nearly warm...
and if i have 2 D2 subs..i could wire them both to 2ohms
so theoretically if i strap my amps and each would be seeing 1ohm(amps), that means im on 2ohms wired for both amps
and fpr wiring 2 D2 subs--you can wire them 0,5/2/or higher
called the guy for the m1b...told me he has about 2 of em still...and i will get em next week...
ordered the m1b..and in about 4-8 days im about to get it
thanks for the necessary info
