Krakin Posted May 1, 2013 Report Posted May 1, 2013 Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Krakin Posted May 1, 2013 Report Posted May 1, 2013 So realistically is a 600 Watt amp then, not really 900 I would assume. I doubt I'm getting 900. I've also turned down a lot of the settings on amp/HU just to make sure I'm not clipping. Don't really trust this amp even though it hasn't ever harmed me (yet). Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
CleanSierra Posted May 1, 2013 Report Posted May 1, 2013 9103 D has only 2 according to Kenwood's website Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted May 1, 2013 Report Posted May 1, 2013 So realistically is a 600 Watt amp then, not really 900 I would assume.I doubt I'm getting 900. I've also turned down a lot of the settings on amp/HU just to make sure I'm not clipping. Don't really trust this amp even though it hasn't ever harmed me (yet). You have a different model than the OP with more fusing. You may be getting the 900 out of it. Im not the one you want to try to troll. Just a fyi for you.
Krakin Posted May 1, 2013 Report Posted May 1, 2013 Had a brain fart and thought mine was a 9103d when i read his was. Didn't even bother finding a manual on it cause when I got mine it was the first part of my system I had and just kept reading over and over the manual. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
i471 Posted May 1, 2013 Author Report Posted May 1, 2013 It has 2 30 fuses and they're still good. It doesn't sound blown but just to be safe..how do i check the coils on the sub? and does the gauge of the wire on the sub matter? The current wires are really small.
soundstream15 Posted May 1, 2013 Report Posted May 1, 2013 12g is perfect for sub wiring. Some ppl use 8awg. I'm using ofc 12awg.
ric006 Posted May 1, 2013 Report Posted May 1, 2013 As far as your question on the amp and what it should run at is hard to say without knowing some more info on your amp. Model number at least would help and making sure your kenwood can run at 1 ohm makes a difference in your decision. The question you have on the enclosure is up to you as well. First off the hole could be left open which would there fore make it a ported enclosure and depending on the size of the box it will make your tuning of the box different. Therefore will it have any negative effects on sound no. Might it sound different yes. It also depending on the enclosure could put more tension on the sub. If you have enough cubic feet in your box your sub won't feel a thing. If it's smaller than minimum specs it will affect how the sub plays. If too small the sub will have a harder time trying to move and cause more tension on the spider and suspension. Harder the suspension the less tolerable for smaller enclosures. Softer suspension allows for more movement and more tolerance in smaller enclosure. Terrible advice on 2 accounts 1) Don't run that Kenwood amp at 1 ohm, it's not stable and will not run well wired at that impedance. 2) The hole where the terminal cup was, does NOT act like a port. It behaves like a big hole in a sealed box. Aiden, if you don't know the answer, don't reply. This is terribly advice and could lead to the spread of misinformation. what my boy said also what kind of wiring are you using in the vehicle
Krakin Posted May 1, 2013 Report Posted May 1, 2013 You can check coils with a digital multi-meter. Edit: yes put on ohm Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
