the handle comes off on most of them
it would help f you told us which car
Edited by Accordman
the window crank has a jesus clip on it.
It is going to be on the shaft, very tight to the door.
If you can see it just unhook the clip an the crank will come off.
It looks like a horseshoe
OK..Listen i had a 2001 chevycavalier...get a rag and go out there....slip the rag in between the window crank and the door and shimmy it in a 360 until a clip pops and then the crank should pull right off...check this site out...
check this site out right here
Heres anothere here
Eclipse cd7000
dude i only live like 15 mins from u too...i could show u but i totalled my car :(
Eclipse cd7000
if you don't have a window crank removal tool you can use a pick usually. As stated above push in on the door panel and the clip will be there... just be careful when you pull it off they have the tendency to launch sometimes... autozone sells replacements if you need one.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
