Need Help Quick With Getting Door Panel Off.
the window crank has a jesus clip on it.
It is going to be on the shaft, very tight to the door.
If you can see it just unhook the clip an the crank will come off.
It looks like a horseshoe
OK..Listen i had a 2001 chevycavalier...get a rag and go out there....slip the rag in between the window crank and the door and shimmy it in a 360 until a clip pops and then the crank should pull right off...check this site out...
check this site out right here
Heres anothere here
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
if you don't have a window crank removal tool you can use a pick usually. As stated above push in on the door panel and the clip will be there... just be careful when you pull it off they have the tendency to launch sometimes... autozone sells replacements if you need one.
-Installer for Duke's Car Stereo
2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
RF Punch 6.5" components and MB Quart Premium 6x9"s
Powermaster Alternator, YellowTop D34, Vmax CT1000
  • Who's Online   1 Member, 0 Anonymous, 1415 Guests (See full list)
