Obsidian 18 + AQ 1200
chad190
Ok, so I made up my mind with what I am going to go with. I want to do 2 Obsidian 18's with an AQ1200. do you think i should go with both subs on the same amp? or should i get an aq1200 for each sub?
it'd be a run of 4 gauge per amp (2 runs of 4 gauge if i did 2)
120 stock alt and an optima yellow top battery
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
5 Cube Box tuned to 32 Hz
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
XS D3100 & Kinetik HC2400 in trunk
Super Start AGM Under Hood
80ft+ Sky High 1/0
40 ft^3 120mil sky high deadener
Soundqubed Pro Audio 6.5" mids
Soundqubed Super Tweeters
Alpine 1" Tweeters
Alpine MRP-F300
They CAN take another 1200 for the pair. If you aren't so experienced, keep it to one 1200 and maybe upgrade later if you're comfortable.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Alright, you think they can take 2k rms together?
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
So,it'd be worth it to save up for an aq 2200? Cause its like what 160 more bucks
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
your gunna want another battery or alt if you go 2 amps probably even with the 2200
An aq2200 will fry them if you ain't careful
Stick with a good true 12-1500 amp
The differance on a daily will be so minimal
If you want to run more power get different sub or more of them
3x15" will have the same cone but will take 2k like a champ and have more motor force
Or even 4x15
Jacob from Sundown emailed me saying a pair would take my SAZ 2k which clamps 2.5krms just fine if gains were set correctly.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
The amps will be set with a dd1, thanks guys! Ill prolly go with one 1200 then go from there
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
  • Who's Online   0 Members, 0 Anonymous, 429 Guests (See full list)
