smerch6969stepoff Posted May 1, 2013 Report Share Posted May 1, 2013 Is there any way to make sure that your sub wont make port noise BEFORE you test it in the box? Link to comment Share on other sites More sharing options...
OrzechNJ Posted May 1, 2013 Report Share Posted May 1, 2013 round the corners is one of the things u can do.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over. Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 1, 2013 Report Share Posted May 1, 2013 Proper box design. Smooth port, constant width ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
TheBetterMethod Posted May 1, 2013 Report Share Posted May 1, 2013 Correct port ratio, and what he said. 2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3 The first build>>> http://www.stevemead...-outback-build/ 140.9 @ 36hz Sealed on dash! REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified Link to comment Share on other sites More sharing options...
Joe X Posted May 1, 2013 Report Share Posted May 1, 2013 Is there any way to make sure that your sub wont make port noise BEFORE you test it in the box? Port area and ratio and sanding sharp edges inside the port as pointed out before, using flared aeros can help. I will also add that if you are really near the port like in some ext cab designs you should be particularly careful with this. Link to comment Share on other sites More sharing options...
