CleanSierra Posted May 5, 2013 Report Posted May 5, 2013 And you tuned to 27 Hz? Good luck with any music that isn't chopped and screwed. What was your point of posting of you weren't interested in the help? Im not the one you want to try to troll. Just a fyi for you.
john253a Posted May 5, 2013 Report Posted May 5, 2013 That box will no way be what the re cal said of 4.5@27 Prob close to 4.2@30
Reed Farrar Posted May 5, 2013 Author Report Posted May 5, 2013 i used this 31.5 wide, 24 deep 17 high then I would suggest doing this: Enclosure Specifications:Fb = 32 HzVb = 4.5 ft^3External Height = 17 inExternal Width = 31.5 inExternal Depth = 24 inPort Width = 3 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front = 27 x 15 1/2Front Internal = 25 1/2 x 15 1/2Back = 31 1/2 x 15 1/2Left & Right Sides:Side 1 = 22 1/2 x 15 1/2Side 2 = 23 1/4 x 15 1/2Top & Bottom = 31 1/2 x 24L Port Internal Assembly Parts:Front to Back = 18 3/4 x 15 1/2Extension = 2 x 15 1/2Assembly guide:
CleanSierra Posted May 5, 2013 Report Posted May 5, 2013 A Joe X Design I see. I hope you're happy with it It looks like you did a good job on cut and assembly. How does it sound? Im not the one you want to try to troll. Just a fyi for you.
Reed Farrar Posted May 5, 2013 Author Report Posted May 5, 2013 it sounds good. and ya thats my 3rd box so i tried to make it as clean as i could get it
CleanSierra Posted May 5, 2013 Report Posted May 5, 2013 Did you do the 45s in the box? Im not the one you want to try to troll. Just a fyi for you.
Reed Farrar Posted May 6, 2013 Author Report Posted May 6, 2013 I was going to but I end up not putting them in cause I only had a jig saw and didn't no how good the cuts would be
ThreehundredC Posted May 10, 2013 Report Posted May 10, 2013 how you like the box i just sold mine i built of that plan but today i wanna build the same box again
ThreehundredC Posted May 10, 2013 Report Posted May 10, 2013 i just cut up this same box wasnt near my table saw so i used a circular saw hopefully it lines up but if i make the extension a little longer(like half inch) that makes the tuning higher?
Guest Posted May 10, 2013 Report Posted May 10, 2013 i just cut up this same box wasnt near my table saw so i used a circular saw hopefully it lines up but if i make the extension a little longer(like half inch) that makes the tuning higher? longer port = lower tuning. shorter port = higher tuning.
