Xplay75 Posted May 2, 2013 Report Posted May 2, 2013 I have a sub that dual voice coil if I connect the positive and negative connections to each channel on my rf 1500bdcp will the amp think its a 2ohm load or will it think its 2 4ohm I know if I connect both positive and negative together on the same channel it will be 2ohm but I wasent shure if I did each channel separate on the amp if it would be 2 ohms
skittlesRgood Posted May 2, 2013 Report Posted May 2, 2013 thats a mono amp, it only has one channel. you should probably tell us what ohm load your coils are first. "dual" "sure" If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
Xplay75 Posted May 2, 2013 Author Report Posted May 2, 2013 Yes its a mono amp but it has 2 speaker out conections the sub is dual 4 ohms kicker l7 and each channel is 1000 max and if I connect it 2 ohms ill blow it so I was wondering if I ran 1 channel to one of the outputs and the other to the other output on the amp would it still be 2ohms if I connect it that way or would it be 4ohms
SnowDrifter Posted May 2, 2013 Report Posted May 2, 2013 What coils are they? Dual 1? dual 2? Dual 4? Oh... And read my sig before you respond ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted May 2, 2013 Report Posted May 2, 2013 Yes its a mono amp but it has 2 speaker out conections the sub is dual 4 ohms kicker l7 and each channel is 1000 max and if I connect it 2 ohms ill blow it so I was wondering if I ran 1 channel to one of the outputs and the other to the other output on the amp would it still be 2ohms if I connect it that way or would it be 4ohms Connect the coils in parallel and keep your gain turned down. You can't hook up only 1 coil. If you were to wire in series instead, that would put you at 8 ohms. And you really wouldn't see any power there ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
newls1 Posted May 2, 2013 Report Posted May 2, 2013 correct spelling in title.... Seriously? I love my staffie So anti FACEBOOK it isn't even funny
Xplay75 Posted May 2, 2013 Author Report Posted May 2, 2013 Yes its a mono amp but it has 2 speaker out conections the sub is dual 4 ohms kicker l7 and each channel is 1000 max and if I connect it 2 ohms ill blow it so I was wondering if I ran 1 channel to one of the outputs and the other to the other output on the amp would it still be 2ohms if I connect it that way or would it be 4ohmsConnect the coils in parallel and keep your gain turned down. You can't hook up only 1 coil.If you were to wire in series instead, that would put you at 8 ohms. And you really wouldn't see any power there thank u for your advice
Xplay75 Posted May 2, 2013 Author Report Posted May 2, 2013 Sorry guys for the bad spellings I'm using my daughter's phone and it inserted a different word fixed it
