Wiring for an AQ 2200
Would a 90 amp stock alt + YellowTop Optima Battery under the hood + BlueTop Optima Battery in the back with all the wiring being @ 1/0 support this amp?
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
5 Cube Box tuned to 32 Hz
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
XS D3100 & Kinetik HC2400 in trunk
Super Start AGM Under Hood
80ft+ Sky High 1/0
40 ft^3 120mil sky high deadener
Soundqubed Pro Audio 6.5" mids
Soundqubed Super Tweeters
Alpine 1" Tweeters
Alpine MRP-F300
I think you could get by maybe. I was getting a lot of voltage drop in my Camaro running that amp at full tilt. my setup is in my sig.
1994 Camaro Z28
Skar ZVX 18D2 5.0cuft box 8" port tuned to 36h
AQ2200 on the Skar
PG V754 on the doors kenwoods for now
All knukonceptz 1/0 power and ground
Duralast platinum H8 battery in the back stock 140 amp alt for now
YouTube is pdx94z28
I'm gonna say that would be cutting it close. Maybe throw in another blue or yellow top, double up your 1/0 big 3, and do another run of 1/0 to the rear. Still, you'd have to watch your voltage at the amp like a hawk.
Even with a big reserve, your cutting it very close. If you do go ahead with it, keep a very close eye on your voltage, once you deplete the batteries your alt won't stand a chance.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
That electrical is not gonna work. I have big 3, optima yellow top under the hood, stock alt and kitneik hc1200 and 1/0awg. Dropping in high 12s
Do the big 3 and replace that blue top. Make sure you got a volt meter to watch your volts
Okay, what battery should I run then? It's going on 2 OA 18s. You think I'd be better off going with the 1200 instead?
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
new alternator, not battery. you're still going to have voltage drop with 10 batteries. need more power created, not stored. if you want to be able to play for long periods of time without having to worry about voltage, get a new alternator.
A alternator before anything else. I went so far as to pull all fuses on my t2500bdcp until I get my alternator in. I was dropping to 12.2-11.8. Hopefully it won't be to long before I get the alt. I would rather not risk messing up expensive equipment because of low voltage.
1994 Camaro Z28
AQ2200 on the Skar
YouTube is pdx94z28
Mechman is having a sale on truck alts now, if you have a truck or SUV. Like $341 for most.
Alright, new alt it is! Thanks guys
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
  • Who's Online   0 Members, 0 Anonymous, 1211 Guests (See full list)
