MrBigs63' Posted May 4, 2013 Report Posted May 4, 2013 Guys I was just wondering about this. When you wire your voltmeter (a simple three wire one), are you supposed to wire it the to the battery, the fuse block, the amp terminals, etc? I was thinking the amp terminals seeing that the power comes from the alt before the battery. In this way you could see the actual voltage going to your amplifier. Any suggestions are appreciated.
P4killer_ Posted May 4, 2013 Report Posted May 4, 2013 if you want to see the voltage of the amp, then I always measured voltage at the amp itself.. makes sense to me.. you could measure at the rear batt. but it wont be AS accurate.. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
SnowDrifter Posted May 4, 2013 Report Posted May 4, 2013 I wire mine into my amp. Like literally: Put the leads of the meter into the inputs on the amp along with the power wire. Don't forget to fuse!! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Jessica Posted May 4, 2013 Report Posted May 4, 2013 I wire to the rear battery. Because i have more than one amp Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
MrBigs63' Posted May 5, 2013 Author Report Posted May 5, 2013 How much do I need to fuse the meter for?
SnowDrifter Posted May 5, 2013 Report Posted May 5, 2013 1 amp is more than enough. They only draw .1-.2a ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
