So I finally got up enough money for 2 sets of SD sa 6.5's for my 100.4d .
So should I just wire them up using the supplied crossovers using all four channels
Or
Use the crossover in the amp and use channels 1-2 for the 4 tweets
And channels 3-4 for the 4 mid ranges?
Would there be a noticeable gains by dropping down to 2 ohms and getting 160 per channel and being able to control the tweets level and the mids level separately ??
Ill have to check and see what the mids and tweets actucally ohm out to be sure ..
250 amp mechman alt
Sundown 100.4D
Sundown 1500v2 now goin to the cruze
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
Trying something new
2011 Chevy Cruze
X8
1500v2
Bump
I measured the mid @ 3.1ohms
And the tweet @ 3.2 ohms
So the amp will see 1.5 ohm per channel is that right an would that be too low ?
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
I would give the cross over a try before you go active. See how it sounds if you don't like it you can switch to active later
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Hmm K
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
Well...
Thanx for the help guys!
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
I'd imagine that resistance will be fine, sundown amps are known for people who know what they're doing being able to run super low resistances. I don't think that running a 25% lower resistance will be too low. But, I agree that you should try the passive crossovers first at least until you can get your hands on an CC1 and DD1 to make sure your crossover is right and they're not getting an clipped signal.
*New vehicle and system coming soon.*
BTW I'm going to be doing something very similar,except I'm doing it active off my SAX125.4, so let me know how it sounds I'm very interested in the results. :)
Kewl! I wasn't sure if they would need the extra power or not... I have a dd-1 good protection for my investment! I'm just waiting for my box from Dave the box guy but damn its goin on 8 weeks .....
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
