Electrical help
Video explains most of it I can't figure it out
1999 Durango
Current
2 15" DC level 3 15s
kenwood HU
Cresendo bc2000
Big 3 upgrade
Sky high car audio wire
Coming soon
Cresendo c1100.4
double din
New Build log
http://www.stevemeadedesigns.com/board/topic/168661-99-durango-dc-audio-package-in-and-box-almost-done/?p=2464991
Clean Build log
http://www.stevemeadedesigns.com/board/topic/171619-dc-audio-durango-clean-build/
Any help?
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
Thats pretty odd. I agree checking all your connections again try to make sure you dont miss any.
Your 5.9L should have a 150-160 amp alt so as long as its still healthy it should be putting out a decent amount of juice for your setup.
If you have ANL fuse blocks anywhere check the nuts on those make sure they didnt vibrate loose. Happened to me on the underhood fuse blocks now I use a drop of blue loctite on them and they wont come loose without a wrench.
The thing is is that it's the whole system. Not just the amp. The cigaret light does the same thing
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
get a dmm watch the voltage at your batt as your system plays see how bad your voltage is dropping then see if the alt is charging right, i bet you have dead cells in your batt
It could be dead cells in your battery like Will said ^. It could be bad connections on the battery terminals or corrosion on the battery terminals. It most likely is a battery problem or connection problem right at the battery.
That's the thing it's a brand new battery been charged up new battery terminals and I have good wire going from the battery to the computer part of the electrical box.
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
This may be your issue.
I'm gonna hate
It did it before I bought it. It came to me like this and I've been trying to figure it out
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
  • Who's Online   0 Members, 0 Anonymous, 525 Guests (See full list)
