gibblegeibel Posted May 6, 2013 Report Share Posted May 6, 2013 i have a question on using this program. if you are building a L port into the box how do you see that in the measurements. i was just wondering how do that because if i use the length that i need to get hz i need it is to long for the box Link to comment Share on other sites More sharing options...
Krakin Posted May 7, 2013 Report Share Posted May 7, 2013 are you making it bend in the box? Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
gibblegeibel Posted May 7, 2013 Author Report Share Posted May 7, 2013 ya i was planning on making an L port that corners in the box. also how far should that board be from the back of the box? Link to comment Share on other sites More sharing options...
RobertR Posted May 7, 2013 Report Share Posted May 7, 2013 I could be wrong but for a three common wall slot port box the port has to be the same through out the entire length of the port. So if your box is 20 inches deep and your port is 4 inches wide......run your port 16 inches deep and then turn and finish the port. BMW 325i Kenwood KVT-647DVD re xxx components re 6.5 FR's 2 RE XXX 12's 2 US amps MD3D's 2 batcap 4k's Link to comment Share on other sites More sharing options...
Krakin Posted May 7, 2013 Report Share Posted May 7, 2013 I could be wrong but for a three common wall slot port box the port has to be the same through out the entire length of the port. So if your box is 20 inches deep and your port is 4 inches wide......run your port 16 inches deep and then turn and finish the port. You are right on that. Such as this. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
gibblegeibel Posted May 7, 2013 Author Report Share Posted May 7, 2013 ok thanks guys Link to comment Share on other sites More sharing options...
