Krakin's Single Cab '03 Sierra
lol, torres. ugghh... i am absolutely not capable of ever taking torres seriously.
that tuning calculation is gonna be so damn far off in your application that it is hardly worth even looking at. when you turn the system on and go from your nominal load to your reactive load (which im sure is not a known figure at this point) we have no idea of what your usable amount of power will be, therefore we have no idea of how the subwoofer is behaving in this enclosure, which will all come together to impact the realistic tuning of the enclosure while in use.
and the proximity of the immediate surroundings in the cabin, lets not even start on the impact of that on the tuning of your enclosure.
I'm in dire need to get away from Torres. And I have the sub still hooked up in my truck with the aero tube, I could easily go check the rise if it will matter enough. I'm all for anything you got for helping out with it.
everyone is in dire need of getting away from torres, they just dont know any better, and dont care enough to put in even the slightest amount of effort, time, reasearch, or thought into doing something correct. people are way too willing to accept mediocrity these days.
do you have an aero, or do you just have cut off pvc?
Owner of BigAss Ports
PVC :/
Was using that and if it performed well enough I was going to invest into some precision port aero(s).
But I don't like how it is taking up a considerable amount of the amp rack.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
PVC :/
there is always the option of mounting the amplifier under the seat. i always take the function before form approach. i do what will be the most functional in the applicationl, THEN figure out how to make it visually appealing.
and just a proper aero alone, in that same enclosure, will give you some nice gains in performance vs the pvc pipe.
PVC :/
Definitely going to go for function and everything visual wise is easily subject to change.
  • 3 weeks later...
Pulled out old box and sub.
And working on the new port. The brace on the right was just checking if the holes lined up enough to use that piece. I'll be trimming it down to size later.
Mock up to see if all pieces fit.
null_zpsb6db1b09.jpg?t=1371838296
Got the bracing done.
null_zpsbff6ce28.jpg?t=1371843414
What could this be? :peepwall:
