01VWGREENMACHINE Posted May 14, 2013 Report Posted May 14, 2013 any help would be awesome. i pulled my RF 800a2 out of storage for a year. hooked i up to test it and it started smoking and getting real hot so i yanked the power and ground off the distro blocks. i have never attempted a fix like this but im pretty handy with a soldering iron. i pulled it apart and found the problem i hope but any help would be awesome! i need help identifying the parts and any tips towards fixing the issue. i have included a couple of pics below: this pic has a burnt resistor its the blue one: and this one is the moss fets i believe a couple had melted solder hanging off the pins: any help please! http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
Wicks Posted May 14, 2013 Report Posted May 14, 2013 Those two parts are easy to source and should be easy to replace. Your biggest problem would be tracking down the reason they blew. Simply replacing damaged parts doesn't mean that the problem is fixed and it might make it worse by giving the faulty circuit fresh parts to conduct even more large amounts of current. The other major issue would be removing those MOSFETs and installing new ones. That method Fosgate uses bonds(solders) the FET itself to the circuit board. You can't use a solder iron to replace it. You need a reflow oven or at the very least a large heatgun which may not even be enough as generally the whole circuit board needs to be heated evenly or certain parts will take too much heat and could be further damaged. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
STEvil Posted May 14, 2013 Report Posted May 14, 2013 Getting a hold of those fets is the biggest problem i've found. I bought some for my 800a2 (which I still havent fixed yet, and it has a few other problems) and the shop I managed to finally get them from charged me like $80 The thermal board you dont need to solder to, you can just drill and tap the amp casing where the thermal board sits then use metal bar-straps to hold the fets tightly to the thermal board.. its not perfect, but it works as well or better than the stock setup. As to the resistor, you can find those easily. Just look up "resistor color codes" then match what you have (red black silver gold) and replace it. Just make sure you get a resistor that has approximately the same (or better) wattage rating. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
98GCLimited Posted May 14, 2013 Report Posted May 14, 2013 From what I can see in the pics your fets look fine. That resistor is burnt in the first pic one of the 4 blue ones on the first pic. You read the color bands on them to determine what kind of resistor they are as far as resistance quantity in ohms and % tolerance. Your is a 4 band resistor because it has 4 color bands. So you would read it like the resistor example on the bottom of the chart. Starting at the bands closest to the edge of the resistor you have brown, black, silver, gold on your resistor. I am getting 1/10th ohm with 5% tolerance but I dont know if thats it for sure double check the chart yourself and I also dont know what wattage rating that resistor is either you need to know that also so you know what size to get. Ive only have to do this once on an amp of my own I was also repairing so Im no pro at this lol.
Smoove Posted May 14, 2013 Report Posted May 14, 2013 If the amp is worth it, just sent it to fosgate for a $321 flat fix it price. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
01VWGREENMACHINE Posted May 14, 2013 Author Report Posted May 14, 2013 Those two parts are easy to source and should be easy to replace. Your biggest problem would be tracking down the reason they blew. Simply replacing damaged parts doesn't mean that the problem is fixed and it might make it worse by giving the faulty circuit fresh parts to conduct even more large amounts of current. The other major issue would be removing those MOSFETs and installing new ones. That method Fosgate uses bonds(solders) the FET itself to the circuit board. You can't use a solder iron to replace it. You need a reflow oven or at the very least a large heatgun which may not even be enough as generally the whole circuit board needs to be heated evenly or certain parts will take too much heat and could be further damaged. Getting a hold of those fets is the biggest problem i've found. I bought some for my 800a2 (which I still havent fixed yet, and it has a few other problems) and the shop I managed to finally get them from charged me like $80 The thermal board you dont need to solder to, you can just drill and tap the amp casing where the thermal board sits then use metal bar-straps to hold the fets tightly to the thermal board.. its not perfect, but it works as well or better than the stock setup. As to the resistor, you can find those easily. Just look up "resistor color codes" then match what you have (red black silver gold) and replace it. Just make sure you get a resistor that has approximately the same (or better) wattage rating. From what I can see in the pics your fets look fine. That resistor is burnt in the first pic one of the 4 blue ones on the first pic. You read the color bands on them to determine what kind of resistor they are as far as resistance quantity in ohms and % tolerance. Your is a 4 band resistor because it has 4 color bands. So you would read it like the resistor example on the bottom of the chart. Starting at the bands closest to the edge of the resistor you have brown, black, silver, gold on your resistor. I am getting 1/10th ohm with 5% tolerance but I dont know if thats it for sure double check the chart yourself and I also dont know what wattage rating that resistor is either you need to know that also so you know what size to get. Ive only have to do this once on an amp of my own I was also repairing so Im no pro at this lol. If the amp is worth it, just sent it to fosgate for a $321 flat fix it price. thanks for all the input. and i got a quote from RF for $175. but i would like to see if i can fix it or get it fixed cheaper http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
8ight Posted May 14, 2013 Report Posted May 14, 2013 Working on Rockford amps is... fun... to say the least. They seem to follow that "buy a new one already" philosophy that oh-so-many companies do today. As wicks mentioned, don't just replace parts, they will probably just blow again as soon as the amp sees power. I'm gonna hate
01VWGREENMACHINE Posted May 14, 2013 Author Report Posted May 14, 2013 it was fine till i hooked the woofer up to it http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
01VWGREENMACHINE Posted May 14, 2013 Author Report Posted May 14, 2013 i didnt snap a photo but 2 of the fets the solder melted and was crossed on all 3 pins. http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
8ight Posted May 14, 2013 Report Posted May 14, 2013 i didnt snap a photo but 2 of the fets the solder melted and was crossed on all 3 pins. Oh lord. Has this been worked on before? I'm gonna hate
