RF 800a2 repair help!
01VWGREENMACHINE
any help would be awesome.
i pulled my RF 800a2 out of storage for a year. hooked i up to test it and it started smoking and getting real hot so i yanked the power and ground off the distro blocks.
i have never attempted a fix like this but im pretty handy with a soldering iron.
i pulled it apart and found the problem i hope but any help would be awesome!
i need help identifying the parts and any tips towards fixing the issue.
i have included a couple of pics below:
this pic has a burnt resistor its the blue one:
and this one is the moss fets i believe a couple had melted solder hanging off the pins:
any help please!
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Those two parts are easy to source and should be easy to replace.
Your biggest problem would be tracking down the reason they blew.
Simply replacing damaged parts doesn't mean that the problem is fixed and it might make it worse by giving the faulty circuit fresh parts to conduct even more large amounts of current.
The other major issue would be removing those MOSFETs and installing new ones.
That method Fosgate uses bonds(solders) the FET itself to the circuit board.
You can't use a solder iron to replace it.
You need a reflow oven or at the very least a large heatgun which may not even be enough as generally the whole circuit board needs to be heated evenly or certain parts will take too much heat and could be further damaged.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Getting a hold of those fets is the biggest problem i've found. I bought some for my 800a2 (which I still havent fixed yet, and it has a few other problems) and the shop I managed to finally get them from charged me like $80 :(
The thermal board you dont need to solder to, you can just drill and tap the amp casing where the thermal board sits then use metal bar-straps to hold the fets tightly to the thermal board.. its not perfect, but it works as well or better than the stock setup.
As to the resistor, you can find those easily. Just look up "resistor color codes" then match what you have (red black silver gold) and replace it. Just make sure you get a resistor that has approximately the same (or better) wattage rating.
Hammerdown... 1%
From what I can see in the pics your fets look fine.
That resistor is burnt in the first pic one of the 4 blue ones on the first pic.
You read the color bands on them to determine what kind of resistor they are as far as resistance quantity in ohms and % tolerance.
Your is a 4 band resistor because it has 4 color bands. So you would read it like the resistor example on the bottom of the chart. Starting at the bands closest to the edge of the resistor you have brown, black, silver, gold on your resistor.
I am getting 1/10th ohm with 5% tolerance but I dont know if thats it for sure double check the chart yourself and I also dont know what wattage rating that resistor is either you need to know that also so you know what size to get.
Ive only have to do this once on an amp of my own I was also repairing so Im no pro at this lol.
If the amp is worth it, just sent it to fosgate for a $321 flat fix it price.
thanks for all the input. and i got a quote from RF for $175. but i would like to see if i can fix it or get it fixed cheaper
BIG 3
RF T400.4
all stinger wires
Working on Rockford amps is... fun... to say the least. They seem to follow that "buy a new one already" philosophy that oh-so-many companies do today. As wicks mentioned, don't just replace parts, they will probably just blow again as soon as the amp sees power.
I'm gonna hate
it was fine till i hooked the woofer up to it
BIG 3
RF T400.4
all stinger wires
i didnt snap a photo but 2 of the fets the solder melted and was crossed on all 3 pins.
BIG 3
RF T400.4
all stinger wires
  • Who's Online   0 Members, 0 Anonymous, 1690 Guests (See full list)
