bass juggernaut Posted May 16, 2013 Report Posted May 16, 2013 i am thinking about adding another amp to my system but i only have one set of sub uotputs on the back of my deck and i am not strapping them, how do i do this? i see guys running 4-6-8 amps and think to myself how the hell do they do that with that many amps.
Kyblack76 Posted May 16, 2013 Report Posted May 16, 2013 EDIT- miss read.. Y splitters... edit - what amp? some have pass through's... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
bighossf150 Posted May 16, 2013 Report Posted May 16, 2013 all of mine are daisy chained Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
bass juggernaut Posted May 16, 2013 Author Report Posted May 16, 2013 don't you lose signal by using Y adapters? and what if i want to run 6 amps?
bass juggernaut Posted May 16, 2013 Author Report Posted May 16, 2013 if i use pass through dose the first amp get more voltage then the other one? should i use a line driver on each amp or just the line from the deck?
BoomZoom808 Posted May 16, 2013 Report Posted May 16, 2013 This doesn't matter really, even if the voltage was different you would still set the gain on each amp independently. Wire from the deck and use the pass through. No need to over think it. if i use pass through dose the first amp get more voltage then the other one? should i use a line driver on each amp or just the line from the deck? 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Lifted2000Ford4x4 Posted May 20, 2013 Report Posted May 20, 2013 CC1 and y splitters or a pass though on the amp
