so im building a box, and i downloaded the torres box calculator...
now the thing is...i dont get it with the aero ports..
1.)so first..ive seen a setting inch or centimeter...im using the centimeter unit
should i use the inch?---over here the Centimeter unit is verry used as normal
2.)when going with the aero port(s) i type the diameter, number of ports...and i use the iner dimension..and still the tuning gets me to 16hz??, im doing something wrong and need help
(the HELP in torres is confusing me..)
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
tried that...but the tuning gets nearly to 18hz
box measures are 47cm height, 94cm lenght, 33cm deep
for 2 12s with 1 6inch AERO port in the midle
am i doing something wrong? the units are set in centimeters
info?
Don't use height and width for aero ports on torres. Just use diameter.
Car: 2000 Ford Focus 4 door
HU: Kenwood KDC-X395
Front Highs: stock
Back Mids: Stock
Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz)
Amp:Audiopipe APSM 1500 mini
Wiring: KnuKoncepts Kolossus 4awg
This is what your wanting to do, use 2 ports as one is just not enough.
the problem is that i only have place for 1 6 inch aero in the midle...other wise i would have to build another box
a guy got me with the same spec but with port lenght is 35cm and the tune would be 52hz? with a single aero port of 16cm
so im kinda confused...
should i listen to the guy or use torres instead?
also.-...if the unit is set in centimeterr...the inner port is set in inch?
