You have both a slot port and an round port entered into the program. You need to pick one or the other lol
if im not mistaking in Port dimensions..height and width are for a slot port, meanwhile # of ports and diameter are for a aero port if im right (lenght are for both the same)
also in port dimension..width means the dimension of the box air hole?
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
help??
if i use 2 subs..do i double the woofer displacement?
Yes, the displacement would be for both woofers.
For some reason when you input everything in metric getting the right tuning seems to be off, so if i convert everything to standard and input it your port would need to be 35cm long to get a tuning of 35hz. I would suggest to play with the tuning in standard sizes to get a more accurate figure and then convert it over to metric for building it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
thanks....i found out that using torres for normal non-aero ported boxes makes things a lot easier----so id go rather with a slot ported one..+ less holes to drill
