ncc74656 Posted May 17, 2013 Report Posted May 17, 2013 i want to rebuild my system and this time i want to tune it properly. if i buy an analog o scope what is the procedure for settings gains on an amp to ensure you do not have clipping? i want to do this for mids, highs, and subs. nothing, gutted
ToNasty Posted May 17, 2013 Report Posted May 17, 2013 buy a dd1, its easy and straight forward, then het the hp to 80-100 and call it a day ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ncc74656 Posted May 17, 2013 Author Report Posted May 17, 2013 issue is an o-scope is 40 bucks and the DD1 is 500.00, thats more than i want to spend. nothing, gutted
ToNasty Posted May 17, 2013 Report Posted May 17, 2013 a dd1 is 150 but ok, and I have never seen an o scope for 40 bucks ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Sean.D Posted May 17, 2013 Report Posted May 17, 2013 Any o'scope for 40 is not going to be anything close to accurate.. A decent one (not good) o'scope will cost you atleast double what the DD1 would ^ so best bang for buck would be the DD1. 2x Sundown SA-15s 8 cubes tuned to 30hz sealed in trunk Soundstream Rub 1.1600 Soundstream Rub 5.800 4x Kinetik hc600
ncc74656 Posted May 17, 2013 Author Report Posted May 17, 2013 i found the 150 dd1, the link i clicked on was for the triple pack. at 150 thats better but craigslist has oscopes for 40 bucks, the old analog versions. id prefer analog to digital and id like to see the sine wave as opposed to a red dot. how accurate is the dd1? if i went with an oscope what would i need to test it, i couldnt put the scope right to the terminals as i would need a load, run it with the sub? nothing, gutted
kickass audio Posted May 17, 2013 Report Posted May 17, 2013 You just play a test track like the ones from damoreengineering.com that they have for the DD-1 and set the gain while looking at the o-scope to see when the peak and valley of the sine wave remain rounded. You don't want to see it get flattened out as that is clipping. Now if you were going to want better detection id recommend the dd-1 as it detects both distortion and clipping. Its hard to detect distortion though with an o-scope as it is usually so fast the scope can't pick it up. And for tuning the crossovers on the amp the cc-1 helps a ton with setting them. a good xover makes the system sound so much better. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
mrd6 Posted May 17, 2013 Report Posted May 17, 2013 Link to $40 oscope? lol My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
ToNasty Posted May 17, 2013 Report Posted May 17, 2013 yup its 500 bucks http://www.wccaraudio.com/smd-install-tools-electronics/distortion-detector/smd-distortion-detector-dd-1.html ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ncc74656 Posted May 17, 2013 Author Report Posted May 17, 2013 i have been debating on the cross over side of things. currently i use my amps and deck for that, basic 4 selection frequencies on the deck and HPF/LPF on the amps. (kicker and MTX). my thoughts were to maybe buy a better deck with the 16 channel EQ and upper and lower xovers built in for each RCA. OR maybe keeping this deck and buying a really nice Xover that will handle 3 ins and outs for lows/mids/highs. my current deck is 4V and the new one would be 5V but im not sure if it really matters, maybe keeping this deck and going with a signal processor is the best choice. in either case id just like for once to know if my amps are truly maxing or not. nothing, gutted
