well on certain notes it sounds like a rattling noise i let my buddy hear it and he said it was distortion cause my voltage was dropping so i seriesed my voice coils at 4 ohms and he said my lpf was set to high so he changed it now im picking up less notes and its still doing it.any ideas on what it is on most notes its real clear and hard but then on some theres no sound just that rattling noise and my voltage dont drop at all now so i know its not distortion i think its a defect in the speaker
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
sounds like a messed up coil starting to unravel or come loose, or even possibly rubbing.
Tap on the side of the cone when the stereo is off, and just push the cone in and out a bit, if you hear it, its the coil.
no tried that pushed on the center and squeezed the sides to see if it was wobbling didnt hear nothing so im not sure is there a way to test the coils?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
Digital volt meter is about the only way, and see what ohm each coil is. If you got dual 4 ohm coils, and you have a coil reading signifigantly higher you have a burnt coil, and even tho its still working, it will fry soon.
If everything is fine, then chances are you are clipping or bottoming out so turn the gain down a bit.
nah i seriouly doubt its clipping and i know its not bottoming out it has a 2 1/2" excursion motor its just one some notes. i'll try the coil thing when i find my volt meter
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
maybe its that humungous box? not saying it is but maybe you should try free airing it on low power to see if its the sub or just that when its in the box and your slamming on it your excessing the mechanical limits.
what would cause clipping? the amp is 1500 rms at 4 ohms i got a kinetik 1400 and 180 amp alt and voltage dont drop so i dont see how i'd be clipping it
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
dirty signal = clipping it can come from a cd or u have it turned up too much
but to me it sounds like there isnt enough pressure for the sub and its bottoming out quick
smaller box ftw
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Number of things.
headunit could be clipping, giving a dirty signal through your rca's.
gain up to high.
bass boost up to high.
What amp do you have, 1500 rms at 4 ohms is quite impressive.
no same box just started it about 2 days ago maybe it is clipping i noticed its only one on or 2 cds it does it wish i had my pioneer with my ipod hook up i'll try it on an actual cd not a burned one and the sub can handle as much as 13 cubic feet with twice the port area i got george from atomic told me i can do 5000 watts with the box i got so i know its not that
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
