Civic Wall Build, Destorys Windshield w/ 4 Sundown sa 12's on 1 Crescendo Audio 5500
I finally got some more work done on my build. All the inside birch is up. I got some fiber glassing done; however I still have more to do on that. The next step will be the front baffle.
Finally done with that :)
I started applying the resin and fiberglass, but I haven't got it done yet.
I also started on the wiring.
Got to have those car audio stickers. lol
fiber glassing for voltage meter... not to bad for a first :)
My YouTube Chanel: http://www.youtube.com/user/cxmaudio *subscribe*
Here is the wall build design. Like I said before, the wall will have interchangeable aero ports. I might build some slot ports to. I have never seen a wall build like this before. let me know if you have :) My friend Mike designed this for me. It is inspired by his camry trunk wall. as you can see in the video below....
The first port I will be building is the one on the right. the ports are both 9.5 inches in diameter. The tuning will be 34hz.
The port on the right will be about 12 inches in diameter and will be tuned to about 30hz ( low bass ftw ;) )
Mike's camry build
http://www.youtube.com/watch?v=BXzBSdmfz6g
I like the interchange-able sonotube idea, love the efficiency and port area you can get from them.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Things are really starting to come together now. I got the front baffle on, looking pretty sick!
Building the front baffle, It is double layer birch for the subs to screw into. then another layer will be going on to flush mount the subs and make everything look good.
the most handy tool ever :)
Big thanks to mike for helping me out with the front baffle.
Next step will be building the port.
Hello
How did you make your first wood layer stick to the metal of the car securely?
Did you screw into the metal or glue the boards to the car?
Thanks
I'm not to sure what you are asking. For the false floor I have 2x4s bolted through the frame of the car. The front baffle is screwed to wood. I hope I answered your question. Feel free to ask any more you might have.
im really digging this build, keep up the good work!
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Looks really good man tuned in!
2000 blazer LS
240 mechman
2 b2 HN v3 15s
crescendo bc5500 @.5
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/
142.8db MECA
2016 PA state champ mod 1 class
  • Who's Online   1 Member, 0 Anonymous, 1709 Guests (See full list)
