rambronco Posted May 24, 2013 Report Share Posted May 24, 2013 Whats up fellas, I wanted to get some input on what you guys think. I have 4 Sundown audio SD-10's that will be pushed bey a Planet audio BB2400.1. After doing some measurements I dont think I can get optimal box volume for all 4 in a ported box so I was thinking of dropping it to 3 of them in a ported enclosure, that would raise the impedence a bit so I figure about 1500 watts. Or I can run all 4 of them in a sealed box and give them about 2K watts. I am more concerned with the lower frequencys which is why I am thinking of giving up cone area and wattage to be able to tune lower. Do you guys think with the extra cone area and wattage that I could get as much low frequency output with the sealed setup? Thanks RB 01 Chevy Silverado X-cab 2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's. 2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp. Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage. 96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time. Link to comment Share on other sites More sharing options...
bkolfo4 Posted May 24, 2013 Report Share Posted May 24, 2013 I would do 3 ported. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
TeamHT Posted May 24, 2013 Report Share Posted May 24, 2013 Agreed ^^ Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
TaylorFade Posted May 25, 2013 Report Share Posted May 25, 2013 Ported Link to comment Share on other sites More sharing options...
rambronco Posted May 25, 2013 Author Report Share Posted May 25, 2013 Sounding kind of unanimous at this point....any other thoughts? I'm torn as to what to do, I have 4 subs but on the other hand im kind of leaning towards ported as well, I've always been a ported guy and to top things off it would be a little easier on my electrical since I don't have dedicated batteries for the amp, although it is a diesel so I do run 2 group 27's with the stock setup. RB 01 Chevy Silverado X-cab 2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's. 2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp. Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage. 96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time. Link to comment Share on other sites More sharing options...
