preamplifier clipping wont do anything to harm a driver like a cd or radio correct
but suppose that clipped signal goes into an amplifier wont it just come out as an amplified clipped signal?
i cant grasp the concept that clipping from an underpowered amp wont kill ur sub
alright lemme give u a scenario
u have an 18" BTL, it can handle loads of power... if u have a 500w amp and u have the gains turned up all the way up it wont be putting out the 2000 rms needed by the sub correct? and ur tellin me that the BTL will not be harmed?
Megalo and Micky i need this to be very clear. help me pleez
Wouldn't sending a clipped signal to an amp kill the amp after a while?
About the BTL thing, yes. It'll be harmed as the amp is trying to put out more power than it safely can and will send a clipped signal to the sub.
I think they said it would take a long while to hurt the sub though. My question would be what's the point in spending the money on a 2000rms sub and only getting a 500 watt amp?
that was a hypothetical extreme situation
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
-dirty signals can come from music, the headunit or the gains of the amplifier
Amen! I was quite suprised to find that my deck started clipping at 60% volume. Good write up.
SOOOOOO I got a question
I have a Rf T3000 and 18"BTL with all the options and dual 2ohm coils wired in Parralel. I followed the amplifier gain tutorial and set the maximum voltage @ 61.7 Roughly 3700 watts.I set this with the HZ @ 50 and the Bass knob ALL the way up with the deck volume on 3/4,Playing a 60Hz Test Tone. How would I know if my speaker is clipping if the BTLs are known to handle more than 3k (Best example Steves Tahoe) and im right on the money when i set the voltage/gain comin from my amp?
Hey i cant really answer your question but Im sure youre supposed to have the bass knob all the way down when you set the voltage. Thats how i set my T2K1. The bass knob is a little over halfway up, any more and it is clipping.
Guest MegaloManiac
that still means you are overpowering it if something cooks ;)
a clipped signal will send the amp into "clipping"(filthy power) faster. the clipped signal wont do anything.
so it comes down to overpowering again
so clipping creates overpowering?
look at my example cause it seems impossible to me
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Guest MegaloManiac
yes.
clipping itself will not harm your driver. Overpowering a driver will. Because you will reach the thermal and mechanical limits of the driver....
clipping will only ruin a speaker if its too much power for the speaker
an amp that puts out 100 watts, at full clipping, is LIKE putting out 2x the power (200 watts) but if its hooked up to a 500 watt sub, it wont hurt the sub
and if you understand that, youll understand how a 75 watt amp CAN cook a 100 watt speaker
Alpine 9887, Oz 180CS, RF R500X1D, 12" RE SE
Guest MegaloManiac
winnar!
