So got started on the amp rack for the the RF t2500.1bdcp and the 360.3. I also left a slot open for another 2500.1
Test fit
can you guess what this is?
I couldn't decide how to do the window's for the amps so I just took the diamond logo and expanded it
Then I decided to do this!! :D
after bout an hour of using the jigsaw I came up with this!
Did a few adjustments and had to double check the fitment before I did anything else
Was good to go so I started marking the panels to mount the magnets!
Magnets glued in so I used a roundover bit along the edge, also covered up all the holes with bodyfiller and sanded it all down.
My 03' sierra crew cab Here build in progress
So I had to build my own center console. Reusing the factory cupholders though. I ended up having to do some surgury on this one because once I cut out the hole for the cup holders I realized they dont sit flat. The factory one is angled so when I put the cup holders in, I notced the drinks are slanted WAY back. So had to cut out the panel then angle it where the drinks would sit level......short version it's fixed! But these are pictures of the console before it was fixed.
I Did use a roundover bit along all the edges
Thanks, got lot's to do tomorrow! This amp's going to look alot better once it's bed lined and painted(hence my profile pic). So expect more updates throughout this weekend
Hmm I dunno, I have an angle finder so when I work on it tomorrow I'll check it and post it with a picture or something. I'll have to check out yours when your done
Got some new carpet for my truck the old stuff was dingy and had lots of soda stains. I bought it a long time ago from I don't know where, wish I did so I could warn people not to buy it because it was not oem replacement like it said. I had alot of trimming to do, and it does not lay how it should. In this pic you can see how much I had to cut off each side so it would fit.
Lot's of leftover's, but you never know when you'r going to need some strips of carpet for padding so I held onto it.
How about some 75lb batteries to mold that carpet into place!
Decided to tape off the Rockford logo's and paint um' Fosgate red!
Came out good but I needed to paint the insides black so that the contrast is better
Did some sanding and painted the inside with just rattle can bedliner
  • Who's Online   0 Members, 0 Anonymous, 1705 Guests (See full list)
