in search for new 10 inch sub
you mean 12"
most 12 are in 2
and if your 2 gross, it might be a 10, but youll need a bit more info then that
like the meserments of the box
power you plane to run
budget
and if the net works out to be to much
there are a few options you could do
1 add bracing or something to decrease the net
less power
2 cubes ported for a single 10" sub it's definitely in the larger side. If you don't send a bunch of power to the sub, then you'll get one(depending on the sub) that digs lows well. Depending on who built this box, if it's a prefab, and port area it COULD be a good box to drop a nice 10 into.
So it's a lower power sub then? Well you may stick with lower power handling subs and not throw more than rated power at the sub in question. I'd suggest Sundown E series, or Skar IVX series.
Ditch the box and start fresh, get the subs you want and build the box for them instead of the other way around which can be tricky and most times not worth it.
The BOX is always built for the sub and not the other way around.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   1 Member, 0 Anonymous, 1681 Guests (See full list)
