so this will be my first build log i havnt been on the forum in a while but im coming back in a big way. this is my 98 neon.
View My Video
not sure how to put it so it shows in the forum not just a link..
this is what i currently have for it.
kenwood ddx419 receiver. still need to get the back up cam for it
rockford fosgate t152-s-5.25
rockford fosgate t1693
audiopipe 1500 16v model
one built re audio se 12 one not built
8g knukoncept cable for sub speaker wire.
as well as knukoncepts 4 chan cables
halo headlights
all of my cables for this build will be knukoncepts still need to get 1/0 for big 3 and bat to rear
what i still need to get
rockford power series 4 chan amp
need to recone both 12s
knukoncepts speaker wire
kenitek 1200
viper alarm
back up cam and xm for deck
stock srt4 rims
current plans cars gona be repainted the same color sept darker with alot of flake then wet sanded to a glass finish. dohc hood,fog bumper plan to delete the sunvisors adding options the car didnt have like p/w p/l heated/ cooled seats cooled cup holders. going to add steering wheel controls for the deck, all black interior gotta re wrap headliner and seats. also plan to add red led lights in cup holders centerconsole vents and in the kick panels have to look into how to do a relayed turn off.
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Thought about trying out a double din in my 95 neon but just don't feel like doing all the glassing needed, and have kicked the idea around to use a tablet instead but again it will be more work right now than i'm wanting to commit to doing on this car as it has some issues and not sure if i intend on keeping it.
The pile of gear looks good and hope everything goes well on the install.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
this is what ive done today.
cut the dask to make room for the new deck
testing fit ment.
seeing what i need to mod on the faceplate
cutting faceplate
testing fitment
deck didnt come with mounting brackets so i had to improvise
and heres the mounts i made
heres how ive been jamming lol an older kenwood reciever hooked to my 6x9s running threw the laptop
thats where im at atm will post more as i go
tested out the mounts today got everything aligned
testing to see if its level
sorry this is upside down idk how to flip it
tomorrow im gona be working on the making the faceplate look good im trying to think about how to go about doing it im thinking of using jbweld to secure the faceplate of the deck to the console faceplate that way ik everythings aligned then going threw with bondo to make everything look smooth then glass/ wrap it so the bottom of the console faceplate looks nice
updates
after taking the power sander to it. went threw twards the bottom so i had to reinforce it
after applying a thick layer of bondo glass
painted it to see where the rough spots were
after sanding it back down to fix the rough spots
final product
a few more rough spots i gotta fix up but over all for this being my first time doing this i think i did rather well
Wow that came out nice man!
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
no glass unless you count bondo glass working on taking the dash out so i can get it painted and put in my components
did some work the other day forgot to take pics of the running of the cables so when i put in my mic for the reciever i took some
heres what i did the other day. took out the dash panel put in the rockford tweaters and woofers.
these are the stock tweaters.
had to cut the frame off so i could modify it to hold the new rockford tweaters
jb welded the rockford tweater frames to these ones didnt take pics of that process so here they are installed with cables already ran. ended up running the speaker cables from the trunk threw the right side into the glove box to the cross overs then all the speakers go to that.
left rockford woofer jb welded to the stock speaker housing frame
right
crossover location. needed somewhere where i can finetune them. these crossovers have the options for on or off axis right now there set to off due to the placement of my tweaters. you can also run 0 or + - 2 db of tweater atunation
rockford 6x9s installed
running the cables for the mic
but thats where i am atm it was raining out side so i didnt take to many pics. right now i have the mic working so i can use the bluetooth. i love this deck i can call from it as well as play music threw a itouch or iphone. can fine tune front and back speakers. set differnt cut offs sending only certin frequencys to the front or rear. deff love that. ill keep posted when i start on some more work.
  • 2 months later...
