Tarball Posted June 2, 2013 Report Posted June 2, 2013 Big 3 = 3 wires 1. positive wire from alt output to batt pos 2. negative alternator case to frame/chassis ground (clean sanded metal) 3. negative frame/chassis ground to battery negative add those wire to what is already there. use 1/0 preferably ofc - cca is fine if that is what you have already. Not trying to sound like an ass but I'm not sure if you read the post. No offense taken, but I'm not sure if your read my response. Specifically the part about leaving the factory wiring in place and adding the 3 pieces of 1/0. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Markous Posted June 2, 2013 Report Posted June 2, 2013 No offense taken, but I'm not sure if your read my response. Specifically the part about leaving the factory wiring in place and adding the 3 pieces of 1/0. Not a bad idea either, the factory wiring was a PITA to get at. I seriously considered this when i realized how involved this project was going to be. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Chipmunk-Alero Posted June 2, 2013 Author Report Posted June 2, 2013 Yea ima leave everything just making sure there is an easier way to do big 3 and can run my wires where I want. Thanks guys 2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d Big 3 and KNU 1/0 Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube) 1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3. Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
