Pulling truck out of the garage for first time in 4 years
I know I'm going to have to change the fluids out. Probably just do a full tune up. Here is a list of everything I'm going to do in the next week or so.
1. Change engine oil and filter
2. Replace radiator fluid
3. Possibly replace transmission fluid (transmission was replaced 5k miles before truck was parked so it's newish fluid)
4. Change the spark plugs/wires and air filter.
5. Need to get a new battery
6. Going to replace the Cats since it will most likely not pass smog without new ones in
7. Replace rear end fluid
Am I missing anything that I should check or replace? Going to have to drop the gas tank and get the old gas out of there (pretty much a full tank wasted :( )
formerly known as Blue86f150
this sux camel dicks
Glad you mentioned the gas. 4 y/o gas isn't gonna work too well.
Make sure any vacuum line, radiator hoses, heater hoses, etc., aren't cracked or dry rotted.
Go ahead and get a new radiator cap and thermostat. They're both pretty cheap.
SMD Super Seller
My Feedback Thread
Yea I need to get that gas out of there, no idea where to put it though. probably have 15 gallons of gas wasted there. I'll check all the hoses also. The radiator cap is fairly new. Had to replace it since it came off on me one time driving up the canyon. Probably replaced it 4 months before I parked the old gal.
Dry rotted tires.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Dry rotted tires.
I believe the tires should be fine since it has been in the garage and not in direct sunlight. We shall see though. They are still fully aired up also, haven't lost pressure at all.
Dry rotted tires.
So was my car. It sat in a garage for 2 years, and daily driven before that. After having a blowout in the winter after a snow storm, to me.. It's worth looking over lol Good luck B)
LMFAO so true
:blush:
Change the fuel filter to I hope your line isn't gummed up and you fuel injection is going to need to be cleaned
Well got the truck out of the garage. Took the battery out of my Jetta and threw it in the truck. Fired right up with no hesitation (the belt squeal is the the alternator belt, needs to be tighter).
http://s245.photobucket.com/user/blue86f150/media/20130610_190238_zps1949bd85.mp4.html
Here is a picture of it just pulled out of the garage.
It is back in the garage now, but it is backed in so I can work on the engine without having to pull the whole thing out to work on it. Still a long list to complete, but it will be done quite quickly.
