Need help with setting up battery(ies) and alt(s)
Ok so let me try and give as much info on what i want to do.
I have a 2000 tahoe with a 5.3l vortec motor from an 05 tahoe. i want to run my audio system, a computer at about 250 watts of power, and of course all the vehicles stock electrical stuff. so i was wondering what i would need. i thought 2 HO alts but that might be a bit too much. or i was going to leave the stock alt in for the vehicle, and have the HO alt for the audio. this is what i want to have as an end result: 2 ssa zcon 18" hooked up to an q13500.1 giving me about 4200 to 4500rms watts. then a pc taking no more that 240 watts of power.
this is what i have so far:
q1-3500.1
singer 350a alternator
ssa zcon 18" dual 1ohm sub
plan on getting:
1 more ssa zcon 18"
another singer HO alt if i need it
xs d3400 battery but not sure now many.
truck already has the big 3 done.
what i would like to know is how many batteries i would need?
do i just need the one HO alt?
or two?
or the stock alt for vehicle, HO alt for audio?
can i get any help? i think im fine with the HO alt and maybe two batts, one front, one back. the thing im confused about is the fusing. my amp needs 380 inline. now i know the fuses need to match the wire. i plan on running two runs of skyhigh 0/1. now since im running from front batt to back batt., others recommend fuses near front batt and fuses near back batt. but i dont know what size fuses if i need 4 in total. i might even get those knuconkeptz holders that have 3 mini fuses.
just dont know what amp fuses i need for what i want to do.
Alt is fine
You are needing multiple runs of 1/0 at that point.
Fuse at both ends
Fuse to protect the wire I assume the runs are good up to 300 amps fuse for 300 amps
Knu fuse holders suck imo go on ebay and find cheap ones
Batteries id do 4 3400s if it was me. Or two 3100s at a minimum
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so is this correct?
2 runs of power from front to back, 2 runs of neg from front to back.
fuse both ends near batts. each fuse 300amps? or 150 each end to make the 300? thats what confuses me. also do i need to fuse between back batt and amp?
300 amp fuse both ends of front/back runs, yes fuse runs to amps. Also, id run 2 runs from alt to batt as well...but that's me.
ok thanks. thats the only thing that had me confused about the fuses. now as im going through the stuff im getting, i will be getting sky high 1/0 cca wire which i know 1/0 cca is rated at 250. so would i then just replace all 300a fuese with 250a fuses?
Yeah go with what the wire is rated at.
ok thanks.
  • Who's Online   0 Members, 0 Anonymous, 2700 Guests (See full list)
