Josh Chav Posted June 14, 2013 Report Posted June 14, 2013 Hello all- Ok, any help will be great! I just bought a 2008 Tahoe LTZ and I want to put my L7 15" in it. I just dont have the BRAIN to come up with a design or specs for it to be around 32-34htz. I have access to box building tools just need help designing and dementions. I plan on folding down one of my 3rd row seats that way I dont lose ALL of my room in the back (even tho i will never use :/ ) I want it to be not sealed because I want to BUMP Here are my MAX dementions that I would be willing to use: H: 22 in L: 22 in W: 38 in Thank you for any assistance
Josh Chav Posted June 14, 2013 Author Report Posted June 14, 2013 I have a 1200.1 kicker mono amp. It's always been pretty good
Joe X Posted June 14, 2013 Report Posted June 14, 2013 Here is a suggestion: Enclosure Specifications:Fb = 34 HzVb = 4.5 ft^3External Height = 17 inExternal Width = 41.5 inExternal Depth = 18 inPort Width = 4 1/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 41 1/2 x 18Left & Right Sides =Side 1 = 16 1/2 x 14 3/4Side 2 = 17 1/4 x 14 3/4Front = 36 1/2 x 14 3/4Back = 41 1/2 x 14 3/4L Port Internal Assembly Parts:Front to Back = 12 1/4 x 14 3/4Extension = 5 3/4 x 14 3/4 Assembly guide (generic dimensions): Important notes:- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- The port needs 4 1/4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
Josh Chav Posted June 15, 2013 Author Report Posted June 15, 2013 is the double layer for the top just for support? and would I just glue them together?
Joe X Posted June 15, 2013 Report Posted June 15, 2013 To avoid flex, I do recommend doing it but if you dont want just do the bracing.
